Old 03-23-2018, 12:10 PM   #1
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
2jzgte vvti will not stay running
Hopefully someone here might know, went to try and post on a supra site but you need 100 posts
Ok I just installed the engine and it will only run for about two seconds. But if I unplug the MAF it will run fine i'm sure it throws it in limp mode and runs pig rich but it runs. I have no clue whats wrong and the MAF is brand new so im trying to figure this thing out.
Any help would be great,
dirtdiggler666 is offline   Reply With Quote
Old 03-23-2018, 01:22 PM   #2
Future240
Future Moderator
Future240's Avatar
Have you tried a different maf?
Checked wiring to the maf?
Originally Posted by ThatGuy
Old 03-23-2018, 02:06 PM   #3
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Is the maf correct for the ecu? as in, aristo motor, aristo maf.
Check ecu for codes, check for vacuum leaks/boost leaks(haha maf), timing good?
Does it run with foot on the gas? How are your vacuum lines hooked up?
di-devol is offline   Reply With Quote
Old 03-23-2018, 02:57 PM   #4
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
Definitely sounds like the wrong maf or bad wiring. If the maf is connected and returning an incorrect value the ecu is probably cutting fuel and it stalls out. Also which 2jz? IF its the JDM arristo gtte it has a MAP sensor as well which could be acting up. For whatever reason those engines run a MAF on the turbo intlet and a MAP on the intake manifold.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 03-23-2018, 06:09 PM   #5
dirtdiggler666
Trader Rating: (26)
It is a aristo engine so yes it has a MAP and MAF
If its swapped in a different chassis how can I check codes? I have not tried another MAF yet because I don't have one. Wires look good on the plug end of the harness, its a wiring specialties harness.
Old 03-23-2018, 11:44 PM   #6
di-devol
There should be a blue plug near the ecu on the specialties harness. Jump those 2 pins, should make the check engine light blink for codes.
Checking codes is on the ecu, has nothing to do with chassis.
Old 03-24-2018, 09:58 AM   #7
TrustS13
TrustS13's Avatar
TrustS13 is an unknown quantity at this point
First question, is the motor completely stock or is it modified?
TrustS13 is offline   Reply With Quote
Old 03-24-2018, 11:33 AM   #8
dirtdiggler666
Trader Rating: (26)
OK cool I will see about checking the codes,
The engine is totally stock other than single turbo
Old 03-24-2018, 11:53 AM   #9
TrustS13
TrustS13's Avatar
Stock ECU?
I tried to run my VVTi motor with just a single on it, with stock ECU. It just doesn't work with the stock computer. I ended up buying 1000CC injectors and MegaSquirt 3 Pro.. Certainly not the cheapest solution but it ended up solving my issues.
Old 03-24-2018, 01:04 PM   #10
di-devol
Originally Posted by TrustS13 View Post
Stock ECU?
Shouldn't matter with single at idle though.
Old 03-24-2018, 04:27 PM   #11
dirtdiggler666
Trader Rating: (26)
Yes stock ECU,
But thats odd I have seen many people run a simple single setup at low boost and be just fine. And yes it should idle and run and thats the first step lol.
Also what are the chances of a brand new MAF being bad?
Old 03-24-2018, 05:35 PM   #12
di-devol
Yes stock ECU,
What's the part number on the maf you got? I assume the engine place didnt supply you with one. We can try to search that you have the correct part number.
So far in searching, if the maf is the wrong part number, it won't work correctly.
Old 03-24-2018, 09:04 PM   #13
TrustS13
TrustS13's Avatar
My car did idle just fine with the single but it would just continually lean out (max out the AFR gauge).
https://www.youtube.com/watch?v=mmIeaIAFiOM
Old 03-24-2018, 09:52 PM   #14
dirtdiggler666
Trader Rating: (26)
MAF# 22204-46010
ECU# 89661-3A470
Thanks guys,
Old 03-24-2018, 11:24 PM   #15
di-devol
http://www.supraforums.com.au/forum/...le-build-why/#
https://www.clublexus.com/forums/per...hooked-up.html
Those are a couple of threads worth reading. Did you check for codes? Check vacuum lines and all that?
Old 03-26-2018, 01:59 PM   #16
dirtdiggler666
Trader Rating: (26)
Big Thanks for helping me out guys,
I finally got the car running. I was just about to order another MAF but being a DENSO,TOYOTA part figured it was more likely my fault. There were two problems acually I did not know that the intercooler pipes had to be hooked up. Im in the middle of the swap and wanted to make sure the engine was ok befoure I went any further incase I had to pull it back ok so I just rigged them up.
Other problem is the intake pipe that was made in china well they welded the flange in backwards.
Thanks again,
Old 03-26-2018, 02:10 PM   #17
di-devol
LOL
Thanks for posting what it was though.
