04-18-2015, 12:19 PM | #1 |
custom fabbed motor mounts
Has anyone ever done this? Trying to find a spec/ cut sheet to make them myself. Im a sheetmetal fabricator and I know I could make them. Just trying to not hang the motor in place for measurements. Definitely save me ALOT of time. Thanks
Doing the RB25DET swap into 95 S14 |
04-18-2015, 12:40 PM | #2 |
do a little more research. I've done this, all you basically have to do is line up the shifter the best you can, which may require a little transmission tunnel massaging, center the engine in the engine bay and make sure the bottom of the oil pan sits flat, as in parallel with the ground. You will have to figure out a way to firmly support the engine from the top while you work on the crossmember from underneath.
Beats most aftermarket kits imo |
