Old 02-12-2018, 01:15 PM   #1
V8hoonin
V8hoonin is an unknown quantity at this point
Brake booster upgrade
Hello fellow peoples, i recently did the ctsv brake swap with a 17/16 300zx BMC however my brake pedal feels a little stiff, I'm using a factory 240sx brake booster and I want to upgrade to a bigger one, I know ppl do the 300zx brake booster or the 240sx with ABS brake booster but I wanted to know if there was another car out there that we can use the brake booster from? Couldn't find anything online so I'm making a thread any info will help.
V8hoonin is offline   Reply With Quote
Old 02-12-2018, 01:35 PM   #2
majgoldfish
majgoldfish is an unknown quantity at this point
An automatic S14 brake booster is larger too, and will give more assist in braking.
Was your car originally auto or manual?
majgoldfish is offline   Reply With Quote
Old 02-12-2018, 02:02 PM   #3
V8hoonin
Originally manual
Old 02-12-2018, 03:32 PM   #4
TheRealSy90
TheRealSy90's Avatar
Are you sure you aren't wanting to upgrade the brake master cylinder? I think that would make a larger impact on brake feel than changing the booster.
Such a good signature.
Old 02-14-2018, 09:14 AM   #5
V8hoonin
Bump, anyone do anything different? Think I'm just gonna order a 300zx booster
Old 02-14-2018, 02:26 PM   #6
TheRealSy90
... You mean master cylinder?
Old 02-14-2018, 02:29 PM   #7
V8hoonin
I have a 17/16 brake Master cylinder with upgraded brakes, the pedal feels stiff af so I need a bigger booster
Old 02-14-2018, 02:36 PM   #8
TheRealSy90
Ah, yeah I totally skipped over the part of you already having the z32 BMC. I changed from an s13 booster to a dual diaphragm S14 booster (I believe the ABS booster is the dual diaphragm) for turbo downpipe clearance, and I do believe it also made my brake pedal feel a little bit softer. Is yours stiff just at idle or also when driving around at higher rpms? You could also try going to a smaller diameter BMC maybe? I think that would soften it up some.
Old 02-14-2018, 02:46 PM   #9
V8hoonin
It's stiff no matter what, really not liking the feel, was thinking about getting a z32 dual diaphragm booster but wanted to see if there was another booster ppl use
Old 03-01-2019, 06:29 PM   #10
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Bumping this thread, ordered a s14 booster, but i have a z32 booster on the shelf, any opinions?
supersayianjim is offline   Reply With Quote
Old 03-02-2019, 12:35 PM   #11
burnsauto
burnsauto's Avatar
this doesn't sound like a booster issues. This may be helpful to you. cts-v calipers may look great behind your wheels, be reasonably affordable, and give you the idea that bigger is better...but if the math isn't done correctly, it may be worse than the original brakes on the car. Things like vehicle weight, pad compound, tires, and driving conditions will all dictate a proper setup.
This link may contain info you already know, but may help you in your quest for better braking.
https://www.joesracing.com/master-cylinder-math/
Old 03-02-2019, 05:08 PM   #12
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
try a 1" z32 bmc. a bigger booster may help but a bigger bmc outputs less hydraulic pressure thus giving you a stiffer pedal
@adamcs14
NiSilS14 is offline   Reply With Quote
Old 03-04-2019, 02:15 PM   #13
slider2828
slider2828's Avatar
This is similar as what NiSilS14 just said. 1" or 15/16 is probably best feel.
But everyone on the right track... Its the BMC proportion you need to change. I had 1" from Z32 and felt horrible, still too stuff. Went with a 15/16 from Z31 and it was perfect.
https://zilvia.net/f/showthread.php?t=55708
Turn and Burn!
Old 03-12-2019, 12:11 PM   #14
Wookie384
Wookie384's Avatar
Wookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really niceWookie384 is just really nice
Send a message via AIM to Wookie384
I went Z32 brakes and 17/16 BMC, the pedal was stupid stiff until I swapped in the dual diaphragm Z32 Brake Booster, and now the pedal feels much better. Get the the dual diaphragm Z32 booster.
Wookie384 is offline   Reply With Quote
Old 03-12-2019, 04:55 PM   #15
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Here is some info from www.alphaomegaracing.com Maybe this info can help some people in this thread.
TECHNICAL / SIZE COMPARISON
Car Caliper Piston Sizes Rotor Sizes Pad Sizes Master Cylinder Size
Silvia 180sx/S13 1x57mm 52x20mm 137x53x17mm 13/16"
Silvia/200sx S14,S15 4x40mm 280x30mm 119x71x14mm 15/16"
300zx Z32 Turbo 4x40mm 280x30mm 119x71x14mm 17/16"
350z Z33 Brembo 2x38mm + 2x44mm 324x30mm 120x74x14mm 17/16"
Skyline R32 GTST 4x40mm 280x30mm 119x71x14mm 16/16"
Skyline R32 GTR (NON Brembo) 4x40mm 296x32mm 119x71x14mm 16/16"
Skyline R33 GTS25T
4x40mm 296x30mm 119x71x14mm 15/16"
Skyline R34 GTT
4x40mm 310x30mm 119x71x14mm 16/16"
Skyline R32,R33,R34 GTR Brembo
Evo 5, 6, 7, 8, 9
2x40mm + 2x46mm 320x32mm 132x77x14mm 17/16"
ALPHA OMEGA
Evo 350mm Brembo
2x40mm + 2x46mm 350x32mm 132x77x14mm 17/16"
recommended
e30gangsta is offline   Reply With Quote
Old 03-12-2019, 05:24 PM   #16
Wookie384
Wookie384's Avatar
OP has the 17/16" BMC already installed. No need to change to another BMC, because regardless if you're using a 15/16", 1" or 17/16" you will need an ABS/Auto S-chassis Brake booster or Z32 Brake booster. Just go to your local junk yard and pick one up, to avoid picking a wrong one try to find a Z32 one.
Old 03-18-2019, 03:36 PM   #17
slider2828
slider2828's Avatar
Well either he has to pair a bigger booster to the MC or pair the MC to the smaller booster... Its the same in the end
Turn and Burn!
Old 03-18-2019, 04:11 PM   #18
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
there is also a 1" pathfinder/xterra master that is useful, but it puts the lines on the farther side (closer to the drivers side fender, farther away from the engine) this is very useful if you have a turbo/downpipe right next to the BMC, but you'll have to re-do your brake lines.
Old 06-02-2019, 10:34 AM   #19
Biggoude
Biggoude is an unknown quantity at this point
Hi guys,
A lil late on this but did you find answers for your question?
Does anyone know if a Z33 booster fit a S13?
I broke my booster while braking and hurt a little a bike but everything is fine for both of us fortunately.
But now I'd like to change for a new or at least not 30yo booster cause things could have been very worst if it broke on my previous brake as I was very fast coming at the red light with people :s
Seems I can't find new / aftermarket booster for S13 CA18 but there are remanufactured ones for S13 KA24, would it fit?
Have Z33 front / Z32 rear for information.
I agree with comments, way to go is ABS S13 or S14 booster (seems valve is farther than s13) or even Z32 (but it seems it requires minor modification on firewall).
If not then I guess I'll go again with spare s13 booster and lets pray it lasts.. who knows
Thanks if anyone knows
Biggoude is offline   Reply With Quote
Old 06-06-2019, 02:39 AM   #20
slider2828
slider2828's Avatar
For brake feel 15/16 z31 brake booster. You can get a remanufactured one with 3 flare insert style. Rockauto
Turn and Burn!
Old 06-06-2019, 05:29 AM   #21
Biggoude
Was looking for remanufactured one, seems only Cardone brand is remanufacturing it but.. saw lot of people having issue with it..
I guess it'll be complicated to find something.
Z31 is probably fine but still 30yo booster..
That's why I ask if someone tested with Z33 booster, not very old so can be bought used from someone
Thanks for information.
Old 06-18-2019, 07:01 PM   #22
NashT
NashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choices
I dont think the booster is necessarily your issue.
Bigger MC bore is not a great idea honestly bc you get less pressure but more volume.
Those CTS-V calipers need both- volume and pressure, especially depending on which ones your running 4 piston/ 6 piston.
Check this link before you spend anymore cash on a booster:
https://www.chasebays.com/collection...itsubishi-ae86
Also read this as MC bore size info may be helpful along with his booster recommendations (but focussed on Z32 swaps- but if your running 4 piston may indeed help)
https://importnut.net/300zxbrakeswap.htm#compare
NashT is offline   Reply With Quote
Old 06-19-2019, 08:47 AM   #23
Biggoude
Hello,
If you're replying to me then I don't understand your answer
My MC + booster broke, that's it. In fact they overheated, probably due to the header (low mount but no protection).
MC was leaking cause the plastic protection on a side just melt.
And booster broke I don't know how but probably heat too so maybe the diaphragm inside burnt, then when I pressed the brake air was leaking from the booster and fked my AFR so idle was very inconsistent.
Thanks for links but I already ordered both MC and booster from a 350z (big booster for ABS and Brembo) so I'll reply here soon if it fits well or not so people know
For information, there are 2 settings : booster size (double diaphragm or single) and MC bore size.
Both have an impact on the way braking works.
But in reality you only know when trying, theory is only theory.
My 350z booster is double diaphragm and MC is 1"1/16 si keep you posted how this setup works with my 350z front calipers and z32 rear (without ABS lines).
Old 07-24-2020, 07:49 AM   #24
TheVinylKingz
TheVinylKingz's Avatar
TheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura about
I’m bringing it back from
The dead ! ....
FRONT 300ZX Break upgrade “ONLY” ———use a Z31 BMC “15/16” (Buy at Autozone $90)... or PickyO Parts ($dirt cheap)
S13 SR, S14 KA
TheVinylKingz is offline   Reply With Quote
Old 08-05-2020, 01:38 PM   #25
MrMigs
MrMigs's Avatar
MrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond repute
Send a message via ICQ to MrMigs Send a message via AIM to MrMigs
Originally Posted by Biggoude View Post
Hello,
Did the z33 booster ever end up fitting?
Drifting is just a compromise between you and your car.
MrMigs is offline   Reply With Quote
