04-05-2005, 01:05 PM | #31 | |
but yea guys, basically i was just going too slow, and trying to turn in too sharp. trying to copy monkey man or a lot of the pro drifters. been getting it more, by just going faster and turning in smoothly THEN letting it drift.
facebook.com/SodiumDanceCompany |
04-05-2005, 01:22 PM | #32 |
Try drifting in the rain and learn to push your car through the corner instead of just letting it slide. Try different techniques and use the ones that you are more confterble with. Just letting it slide its like having a fwd car and just pulling the ebrake. Atleast thats how i see it.
04-06-2005, 12:50 AM | #33 | |
j/k im curious on this more rear damp. u should use less rear dampening, that way u have more weight transfer to the front. think about it..... |
04-06-2005, 12:54 AM | #34 | |
i dunno, he is already understeering, yes rain reduces grip, but to all 4 tires, it will be harder for him to get proper weight transfer in the rain,(rain reduces weight transfer to the front during braking, that of course if hes trying to brake drift). |
04-06-2005, 02:30 AM | #35 |
umm doing the braking drift in the rain is kinda an accident waiting to happen..... lock up ur brakes and go straight into what ever is in front...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
04-06-2005, 12:42 PM | #36 |
I dont think anyone is that dumb to go fast and understeer into something locking the brakes up. It can happen though but going slow in the rain and trying to keep a drift isnt that hard though i dont remeber since it hasent rain around here for a while.
04-06-2005, 12:57 PM | #37 | |
the best way to learn how to drift is to do it in a parking lot
honestly, dont try to learn in the street and clutch kick first, that will help you understand your steering...ebraking takes speed, speed takes confidence (or stupidity if youre un-skilled) the only way to gain confidence is to know what you're doing...see where i'm going with this? once you learn how to steer and build up confidence, shy away from initiating w/ a clutch kick and try to steer your way into the slides.
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
04-06-2005, 02:26 PM | #38 | |
Everything you said was correct except for two things. It's best to learn on the track and clutch kicking is how you initiate pretty much all drifts. The only exception would be the occasional long ebrake slide down a narrow straight into a tight 2nd gear corner and even then, you rev up and pop the clutch when you get back on the gas. It's all about keeping your revs high as possible with drifting and one of the only ways to do it is with skilled clutch work. |
04-06-2005, 03:22 PM | #40 | |
04-06-2005, 03:53 PM | #42 |
i dunno, using brakes is a good way to learn how to properly weight transfer. yes its cool to high speed drift, but it takes alot of skill to low speed drift, and the brake is definately the tool to get perfect weight transfer. to each his own i guess, but reality is, events still have braking zones, i still think u should get used to drifting utilizing these braking zones...
04-06-2005, 03:57 PM | #43 |
true true. i just cant stand using breakin tecniques. popin the clutch/dumping it at full throttle gets my adrenaline going
hydropgrahics! ls1...... |
04-06-2005, 05:15 PM | #45 |
put a rear srut tower bar only(having one on the front usually experience more understeer)..
lower the tire pressure a little bit to make the tire "softer" = more grip Leave rear tire pressure at maximum. Also, really good rear tires will eventually cause you to understeer... go with something cheapo like stock 195s... Thats what I had to do when i had open diff to get the car to oversteer... of cousre id make adjustments to front camber and having coilovers helped..
Keep it Classy |
04-06-2005, 07:17 PM | #46 |
I agree really good tires in the back suck for drifting or really crappy tires in the front and it feels like shit when breaking. It almost feels like you are trying to drift a fwd. Breaking techniques and feints are more about weight transfering so its kinda different than just letting the clutch go. Or pulling the ebrake. Its fun but to know to learn how to drift good you need practice your weight transfers just my .02 cents.
04-06-2005, 11:01 PM | #47 | |
and its also not nessicarilly how fast you pop your clutch, but more like when you pop it...timing is of the essense ina drift oriented entry(that and knowing what the hell ur doing) but damn man...sometimes i feel bad for the clutch burning it soo badly like...feeling the vibration in my leg as i hold it semi engaged and sleeping.... /me shivers hahahahahah
LP stylez!! bishes Lazy Penguin since teh 04' Part of the Elite Shasta Speed Stars RIP......05-09-03....*sniff sniff the beast nears completion..... YOU LOOK AND U BUY STUFF !!!!! |
