Old 02-28-2012, 09:08 AM   #1
Lowlifes!
Lowlifes! is an unknown quantity at this point
R33 Calipers question.
I have some red R33 calipers on the front of my S14 and was wondering which size rotor i need to use when i replace them... 30 or 32mm??? <hahahahahahahahaha
Lowlifes! is offline   Reply With Quote
Old 02-28-2012, 09:34 AM   #2
hardparkd
hardparkd is an unknown quantity at this point
"Specs below.
R33 GTST Nissan Skyline
Front rotors (diam x thk) - 296×30
The bolt pattern is 5 x 114.3
center hole is 68mm
min thickness is 28mm
height is 53.75mm
It's pretty much the same as the 300zx except the diameter and 0.25mm difference in height. If you made them two piece you could use the same hat as the 300zx."
Looking for R33 rotors . 296x30 ? - RacingBrake Forums
:dunno: ?
measure the rotors that are on the car currently..?
hardparkd is offline   Reply With Quote
Old 02-28-2012, 09:36 AM   #3
Lowlifes!
Thnx for the quick and detailed reply! Guess i will order me some z32 turbo front rotors!!!
Old 02-28-2012, 09:42 AM   #4
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
FYI, 300zx TT rotors dont work with r33 GTS brakes. 300zx are 280mm and r33 GTS are 296mm diameter.
garagelu is offline   Reply With Quote
Old 02-28-2012, 10:23 AM   #5
Lowlifes!
Well crap, so I actually have to buy them specific for the r33?
Old 02-28-2012, 12:11 PM   #6
hardparkd
wat model of skyline did the rotors come off of..?
this is a site from the UK but anyways
NISSAN Skyline
R33 GTS 2.5 Turbo
Brake Disc Dimensions:
Diameter: 296mm
Height: 54mm
Thickness New: 32mm / Minimum: 30mm
These are 5 Stud Vented Brake Discs
Years: 93 > 98
NISSAN Skyline
R33 GTS 2.0
Diameter: 280mm
Height: 50mm
Thickness New: 22mm / Minimum: 20mm
These are 4 Stud Vented Brake Discs
Years: 93 > 98
im guessin your SOL and gotta source some from a R33. unless you have the 4 lug ones..?
but what do in know, im just posting what i find in the few minutes ive spent Searchin google.
Old 02-28-2012, 02:10 PM   #7
Lowlifes!
The bad thing is i dont even kno wht model they came off of. There just red calipers and there pretty big size. The rotors tht r on the car right now r to small for the calipers. the brakes barely touch the rotor lol. They work just fine but i was just going to replace them with the correct ones!
Old 02-28-2012, 11:05 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Somebody said that they're using 3000GT rotors...but you'd have to space out the caliper. You still have the Q45 option but they're 2mm narrower.
http://zilvia.net/f/tech-talk/433780...ht-rotors.html
CLICK HERE!!!
Old 02-28-2012, 11:23 PM   #9
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
You can use the GT-R 296x32 rotors as well as the 296x30's. I've posted part numbers for OEM rotors you can source through Nissan Motorsports here before.
Mirage is offline   Reply With Quote
