11-23-2014, 01:24 PM | #1 |
Trader Rating: (18)
Feedback Score: 18 reviews
Auto SR20 questions
I have searched all over but I cannot find a specific answer.
I am looking into buying a AUTO S14 sr20 motor/trans. What I need to know is: 1. Are there any differences between the AUTO and 5 speed sr motor?? (same turbo, ECU, etc) I heard the turbo on a sr auto is a t25? 2. Will I have any issues mounting the 5 speed trans? I assume I just need a flywheel, clutch etc and the trans will mount right up? 3. I plan on ordering a harness from WS. I see the ECU is a WE ecu and I have read on another thread it will work. But will I have to mess with the neutral switch etc?? |
11-24-2014, 06:32 AM | #2 | |
the motor and turbo are the same. The ECU is different, the TPS is different, the harness is slightly different to accomodate those differences.
HouseBuyers365.com Quote:
11-24-2014, 08:55 AM | #3 |
You're going to buy it and swap it to 5 speed as soon as you buy it? ...how much money are you 'saving' $2-300? Sell your trans you plan on putting on it and just buy a 5 speed sr20 and save yourself the headache and probably some $$$
11-24-2014, 10:07 AM | #4 | |
Either way, its not much work if you have 5 speed chassis or are converting it to 5 speed. There is a write up from someone about converting the TPS wiring to work. If it were me, I'd take the money I saved from the auto Sr and get a WS harness made; I hated wiring my S13 though...
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
11-24-2014, 12:11 PM | #5 |
I bought my SR auto, and 5 speed swapped it PO liked automatic. And I still ran the auto ecu runs just fine with it only difference is I can start it with no clutch in. And I believe the auto ecu has higher rev limit.
11-26-2014, 06:40 PM | #6 |
Trader Rating: (18)
Yea I already have a 5 speed chassis and a trans! I would be getting a harness from WS. I know the TPS are different I read somewhere once that you only have to use one of the 2 plugs if you have a 5 speed harness.
