View Single Post
Old 10-31-2023, 11:37 AM   #7914
slider2828
slider2828's Avatar
Noice! Finally on the track poorman!!! Lol is that a cut exhaust with those silver hangers? I was wondering what those were..... Isn't it load AF? So happy you finally got it on the track for you.....
Hey any tips on notching my lower bolt hole on my strut tower to have less camber and more coilover spacing between the spring and tire? I can dial in more camber easily at the top plate because of how wide my front lcas are.
I was thinking about making the lower hole about 7mm wider inboard so the tire sits a little less camber than the coilover......
Turn and Burn!
