Originally Posted by projectsupra
Looks like someone chopped them off to avoid the downpipe and then tried to put a flare to hold a hose.
The best tool in this case would be something like this, so you can add the bead without removing the line.
https://www.speedwaymotors.com/Earls...aign=CSEGOOGLE
I did some research after my comment above. These tools "do the job" but the reason I asked is the bead they make is very mediocre. I wouldn't trust it long-term unless you hercules-tighten the hose clamp. It seems like using a brake flaring tool but not quite tightening it to the full inverted flare makes a nice, smooth bubble nipple.
sry4threadjack
