Originally Posted by speedgod^s13
How does the gearing work with the z33 trans? In my case, I have an ATS 1.5 way, with stock gearing. If I were to go with the z33 trans, would that affect anything on the rear end, or would I have to change anything to do with my gearing? Or just slap the trans in and go?
The over-drive gear isn't much taller than the 5 speed. .79 on the Z33 vs .84 on s14. So don't expect low cruising rpm just because you have an extra gear. The difference is in the 2-3-4 gears.
Can plug the ratios into a gear speed calculator and see if you'll need to change up the final drive. Or drive it and make a decision later.
