Consecutive post.
![Smilie](http://icandy.zilvia.net/img/smilies/smile.gif)
Never got an answer gents...
S13 w/ '97+ Q45 diff swap for 3.69 ratio. Pretty sure I got it down, just want someone to check the work.
Already have a '95 or '96 J30 diff in the car with 3x2 stubs and axles.
'97+ Q45 stubs bolt to J30 5-bolt axles? And these axles swap directly into the s13 hubs?
Other option is the pre '97 Q45 stubs w/ z32TT/Q45 6-bolt axles and would need z32 TT hubs right?
And If one was retaining the s13 3x2 half shafts and just bolting in the q45 diff could they just pop out the stubs and pop the ones from the J30 in?
(I'm actually now pretty sure I'm gonna scrap going with the q45 diff because i want a higher numerical gear that 3.69, but would like those questions above answered.)
If using a Ford 8.8" diff, what driveshaft do you use? Does the stock one bolt up? Axles/half-shaft options?
