Thats a timing chain guide. I'd suggest against trying to start or turn the engine over by hand since you timing chain probably has no tension on it currently. I've never seen this happen before, post pics of what it looks like once you get the front cover off. Best case scenario, you replace it and are good to go, worst case you bent valves and damaged pistons...
