Originally Posted by TheRealSy90
I believe the Mazworx kit is actually slightly cheaper than the InsaneDrifters kit. However the InsaneDrifters kit has a way better shifter relocation solution than Mazworx. The Mazworx relocation requires cutting the hole in the chassis although it does come with a metal plate to cover the new hole and clean it up. Also it BARELY clears the plastic shifter trim in S14 and in S13 it actually touches the trim in 2nd, 4th, 6th and Reverse.
I went with the Mazworx full kit myself, had to send the bellhousing back initially as they forgot to machine a relief for the 2nd gear selector rod, and they exchanged it for a revised one that should be arriving in the mail tomorrow.
Hey sylus good to hear from you again. Yeah mazworx hasn't corrected the shifter problem yet but we've commented a lot about better shifter options on the first page.
