Originally Posted by hybrid_eg
245/40/18 and 275/35/18 are nearly identical as mentioned above.. i just ordered Ventus RS-3 to put on RS05RR's which are replacing my NT03+M's pictured above so I'll post some pics once they are mounted.. front tire is 25.7" diameter and rear is 25.6" pretty darn close..
I'll probably move up to 285/35 once i trim the over-fenders a bit.. and that size measures 25.9" diameter.
nearly identical yes, but 245/40/18's will be way tall for the front to have any good clearance. Pictured is 18x9.5+15 245/40/18 with -3 camber and 18x10+38 275/35/18 with 0 camber. it looked aweful IMO and I switched to 255/35/18's in the front. width of the tire was very similar but sidewall profile is way more manageable to deal with in the front.
