Originally Posted by ehhhregartless
can you show a pic of how you mounted the lower canards? i have the same ones but looking into options of how to mount.
i basically just positioned one until i thought it looked good. i see some pics online they are all mounted differently. to me it looked best by making the wing part flush with the end of the bumper and keeping it about 1 1/4" away. then pull the front section out so that where the very beginning of the wing starts to form is 2" away from the bumper.
then i just drilled three small holes about 1 1/2" away from the edge of the bumper. took it off drilled them bigger and used 3 small nuts and bolts with lockwashers and washers to hold it on. its on there good. if i get a chance ill try and take a pic hope that somewhat helped.
then for the other side i did the exact same measurements and it worked out nice. u can see the pic above they are exact the same distances and they are centered .
