Originally Posted by a_ahmed
Finally I get to see your setup live, but like, 17x9+35 and u fit 275/40/17 up front? I know that the custom coilover setup, the housing is meant to add some clearance, but wow?.. no spacers?
Thanks. With an 8" spring I had to use 10mm spacers, so it was a combination of the custom housings and the location of the spring perch that allow me to run this setup without spacers.
a 18x10.5+15 with 295/30/18 would be 1mm shorter in backspace (further away from coilover) than mcoy's setup, sidewall would be 21mm shorter, tire would be 17mm shorter (wow), it would stick out 30mm further out so widebody would be required.. but speaking of the inside.. it would basically have same/better clearance...
You'll have 1mm more clearance from the wheel/strut and stick out an addition 39mm. Also with the tire having a smaller diameter than mine, you won't have as much of an issue keeping the perch above the tire.
