Old 08-17-2012, 10:31 AM   #1
Marino.'s Avatar
Garage Cleanout 2 Tons of RB26, SR20, KAT, S13, RHD OEM and Aftermarket Parts!
Hey Guys, back to sell more and more shit. Tons of parts, little bit of everything, so make sure you scroll all the way down!
Located on long island NY, feel free to arrange a pickup if your local, all prices obo. Willing to ship!!! EVERYTHING MUST GO!!
S13 Parts
Misc Brake parts, all calipers work fine, and have all ready been compressed to make for an easy install. Prices vv
2 front brake calipers left - 20$ for both
2 master cylinders left - 15$ each
4 lug hubs front/rear - 10$ each SOLD!
extended studs - 25$
great picture i know......stock ebrake lines 2 pairs, 5 per line 10 for a pair
mint s13 coupe tails 20 each or 30 for both
s13 sharknose bumper grills 10 each or 15 for both
s13 stock exhaust tips 20
s13 front hood latch support 15
s13 rear shock covers 2 each 5 for all of them
s13 headlight motor 15
s13 headlight motor adjustment knob covers 2 each 3 for all of them
s13 kade ac bracket w/tensioner 20 each
s13 kade starters sold as is, worked when they were in the cars SOLD
s13 kade oil filter block 15
s13 kade shifter, same as sr 20 SOLD
rb20 engine mounts 20 for both SOLD
s13 engine mount - 10
s13 tranny mount - 10SOLD!
rb20 tranny crossmember - 20 SOLD
kade manual tranny crossmember - 20SOLD!
s13 headlight linkage - 15
s14 rear tranny dust cover - 15
s13 kade fuel rails "as is" - 15 each
s13 cruisecontrol steering wheel (comes with center nissan logo)15
s13 hvac with linkage 10 SOLD
s13 drivers side window switch missing button 15
s13 signal stalk 15
s13 gauge clusters with harness 60 each SOLD!
s13 clamshell steering column cover 10 a piece 15 for both
s13 seat cover 10
s13 auto brake pedal cover 5
s13 rear seat latch 5 each
s13 rear seat hinges (i have 2 complete sets not fully pictured) 5 each
s13 pass seat seatbelt latch 10
s13 rear searbelt latches 10 each
Headlight cover - 10
S14? power steering reservoir 10
s14? power steering pump -10
SR20 Parts
S13 Sr20det Redtop Flywheel 40
S13 factory nissan headgasket 50
S13 factory nissan valve seals 20 exhaust 20 intake 30 both SOLD!
S13 factory nissan tensioner gasket 10
S13 factory crush washer 5
S13 SR20 Isis V2 manifold CRacked!! Theres a crack on the weld of the 4th runner, it goes almost all the way around the runner. Definitely fixable by a good welder. Comes with gasket for the mani-head. 60
S13 sr20 Isis top mount cast maniold. Brand new, only used for a test fit. 150
s13 sr20 sidemount intercooler. it has new gaskets and comes with all the oem brackets and parts, as well as new hose clamps. 150
KAT Parts
KaDET manifold. First off let me say that i really dont know what manifold this is. But judging by the casting and the design i actually think its fairly good quality. It looks toO good to be ebay, and compared to the ISIS sr cast manifold i have this looks way better. 250 SOLD!
RB26 S13 *WIP*
Marino. is offline   Reply With Quote
Old 08-17-2012, 10:33 AM   #2
Marino.'s Avatar
Altima kade exhaust cam, if im right this is the one everyone wants 20
S14 Ka mishimoto fan shroud. Never used, never opened, just trying to make my money back. 207
RB26
RB26 OBX manifolds, and stock rb26 twins. heat wrapped manifolds. turbos are in good shape, little side to side play. The turbo to manifold bolts are tack welded together so they wont come loose. You can still break the nuts loose with not too much force if you need to take it apart. Comes with powdercoated white intake elbows, and i can throw the stock exhaust elbows in too 500 OBO
RB26 engine brackets, powdercoated wrinkle black, never used - 50
stock rb26 pistons deringed, and cleaned 200 obo SOLD!
Stock RB26 Twins, they have side to side shaft play, could be used as is, but i recommend a rebuild with the steel fins! Sold as is for 300 SOLD
Factory RB26 oil pump 80 SOLD!
Crank 1 Everything looks great on this one, except the nose, theres some marks on it from when the oil pump gear was forced off, wont be a problem if you machine it and put a crank collar on. 200 SOLD!
Crank 2, everything is perfect on this one, no damage on the nose, bearings look good 300 SOLD
Greddy oil pump. This came on a motor that i got, but the timing gear was forced on the crank, by the time i got the gear off the pump looked like this. (didnt know it was a greddy) Its still useable, but if i was you i would machine a stock pump to accept the greddy gears, and then swap the pressure spring onto the stock pump too. It retails for 1800, ill get rid of this one for 550 OBO, and ill give you a good price on the oem pump i have if you want to machine it, as well as a free front main seal! SOLD!
RHD S13
RHD S13 brake master cylinder 40
RHD S13 clutch master cylinder 20
RHD S13 brake pedal 20
RHD S13 clamshell column cover 20 SOLD
JDM S13 cluster WITH HARNESS 100
RHD S13 stalks 20 each
RHD s13 under steering column cover 20
RHD S13 Shifter trim 30
RHD S13 gauge surround with hazard and defrost button 40
RHD S13 kickpanels 20 each
RHD glovebox with bent bracket, might not come with key cylinder. 20
Universal/Misc Parts
ebay 38mm wastegate 10 SOLD!
ebay catch can 10 SOLD!
black tinted plate covers 5 for both
yes another great pic......z32 vlsd reshimmed and never used 180
ek civic ziptied lip 20
5th gen accord coilover sleeve kit 80 might fit s13?
rb20 lower harness 20
SSR XR4S 15x7? +38 with some yokohamas 600
APR Drag spoiler, you can cut it shorter if the length isnt good for you. 200
HKS bov, came on one of my cars, no fitting on the front, worked fine. 100
Trailer Fender Ready for tubbing, 11 inches wide, has a dent in it, but you can avoid that spot - 20
AGENCY Power S13 Titanium Fatback 450
Holset HX35 Rebuilt, everything is fresh as fuck, got all the paperwork and new gaskets for it from commins, only used it once to test fit. Would go great with the isis manifold im selling. (used for test fit) These rebuilt go for 1000-1400. Im looking for 800 obo
I also have 4 s13 factory electric fans, 10 each or just give me 20 for all of them.
Once again everything is obo, feel free to pm me about anything!
RB26 S13 *WIP*
Old 08-17-2012, 10:35 AM   #3
JJ for Guv'nor
Edwin562's Avatar
Trader Rating: (33)
Feedback Score: 33 reviews
got any mounting bolts for calipers to spindle?
In need of the following items:
1x Heater hose kit for Sr20
1x S13 ABS Driveshaft
1x Dome light cover for hatchback with sunroof.
Old 08-17-2012, 10:52 AM   #4
Interested in the RB26 crank when can I pickup?
angels one is offline   Reply With Quote
Old 08-17-2012, 10:52 AM   #5
Trader Rating: (25)
Feedback Score: 25 reviews
good parts here man
Old 08-17-2012, 11:36 AM   #6
armiller91's Avatar
Send a message via Yahoo to armiller91
Interested in a cluster if its DOHC..
PM me please
-1990 240sx
Operation New Dawn 9/10-9/11
armiller91 is offline   Reply With Quote
Old 08-17-2012, 01:49 PM   #7
ETHANOLED SR's Avatar
Trader Rating: (30)
Feedback Score: 30 reviews
Nice thread, very organized and straight to the point! Check your pm.
ETHANOLED SR is offline   Reply With Quote
Old 08-17-2012, 06:37 PM   #8
Marino.'s Avatar
I did but everyone kept asking me for them, so they're all gone. If I'm right the thread pitch is 12x1.25, maybe a hardware store can get you some.
Originally Posted by d_nice View Post
good parts here man
Thanks!
Thanks, I buy stuff alot, so I know how to make it easier to buy.
All pms replied!
RB26 S13 *WIP*
Old 08-17-2012, 07:30 PM   #9
Still got the coupe tails?
white92hb is offline   Reply With Quote
Old 08-18-2012, 07:31 PM   #10
Marino.'s Avatar
Yep^ Pmed
THREAD UPDATED WITH WHAT SOLD SO FAR AND PICS OF RHD ITEMS!
RB26 S13 *WIP*
Old 08-18-2012, 08:16 PM   #11
Turn signals are mine! Thanks for the quick shipping
b00st3d is offline   Reply With Quote
Old 08-22-2012, 05:41 AM   #12
silvias121987's Avatar
Im out in long island aswell anyway i could come buy and possibly buy sum parts?
silvias121987 is offline   Reply With Quote
Old 08-22-2012, 05:03 PM   #13
Marino.'s Avatar
Yea, what are you interested in, I pmed you.
RB26 S13 *WIP*
Old 08-22-2012, 06:24 PM   #14
pgfd240's Avatar
s13 headlight motor (do you have both of them?)
also
s13 kade fuel rails "as is" (do thease come with the injectors?)
pm price shipped to 20905
pgfd240 is offline   Reply With Quote
Old 08-22-2012, 11:35 PM   #15
Bump for a legit seller with fast shipping!
Old 08-23-2012, 12:32 AM   #16
jdm2191's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
How much for the S14 PS Resorvoir shipped to 92551?
jdm2191 is offline   Reply With Quote
Old 08-23-2012, 08:56 AM   #17
my1s14's Avatar
KaDET manifold and HKS bov shipped to 15701?
my1s14 is offline   Reply With Quote
Old 08-27-2012, 01:07 AM   #18
Marino.'s Avatar
Sent a pm to all you guys ^^^^
Thread updated, DROPPED A FEW PRICES!
RB26 S13 *WIP*
Old 08-31-2012, 05:40 PM   #19
blackmagic240's Avatar
Send a message via AIM to blackmagic240
Im interested in the other rb26dett crank you have. I sent you a PM I have paypal ready.
taking life a day at a time never looking back.
blackmagic240 is offline   Reply With Quote
Old 10-02-2012, 08:08 PM   #20
how much for rhd defrost button and rhd steering column stalk(just head light one)
SilEightyRHD is offline   Reply With Quote
Old 10-02-2012, 09:42 PM   #21
Still have the power steering pump? How much shipped to 67212? Have cash in hand. Thanks
240sxracerb25 is online now   Reply With Quote
Old 10-04-2012, 04:14 PM   #22
MalditoJay's Avatar
Damn Marino you have like half your life posted on here. Lol
MalditoJay is offline   Reply With Quote
Old 10-05-2012, 12:23 AM   #23
Marino.'s Avatar
40 shipped
pmd, hope its the one you need
You know it!
RB26 S13 *WIP*
Old 10-05-2012, 08:12 AM   #24
You have a rhd s13 center console ? Pm of you do thanks
s13Latchy is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
