Old 08-06-2012, 12:32 AM   #1
drftx's Avatar
Send a message via AIM to drftx
fs 1 full sr swap and 1 semi built long block
please do not waste my time and i will do the same
contact info is 847 890 3073 or pm either one
I have a nissan sr20det motor for sale it is a full turn key swap this is what you will be getting
- low mileage sr20det
- harness
- ECU
- Fresh OEM gaskets all around ( was not cheap came from touge factory and nissan )
- Minty fresh T-25 turbo
- Brand new Megan tubular manifold
- Brand new Megan turbo elbow
- Trust/Greddy 3inch down pipe
- Brand new circuit sports Turbo lines ( oil,coolant,oil )
- New 370cc injectors
- New coil packs
- New Brk7e NGK spark plugs
- New Touge factory Hot pipe
- Greddy style type s BOV
- Greddy LM intercooler
- Greddy intercooler piping
- Brand new Touge Factory couplers
- T-bolt clamps all around
- Apexi super suction intake
- Low milage sr20det 5 speed transmision
- Low milage spec stage 3 6 puck un-sprung clutch
- Painted sr20det valve cover
- Painted coil pack cover
- Painted injector caps
- Painted intercooler piping
- Brand new circuit sport oil catch can
- Greddy polished water inlet
- Stock sr20det radiator
I probably have more in to this motor runs great all you will need is a MAF ( mas air flow sensor )
OBO and NO TRADES i need money to fund my new motor
i also have a BUILT 0 milage sr20det motor its a LONG block all it needs is a new head
( or fix the current head just one of the intake valve seats needs to be fixed the current head has 0 miles everything is checked and in spec also i did a 3 angle vavle seat job my classmate fucked one of the seats up im sure pavel can put a new seat in it for cheap )
block was built by me at school and checked by pavel
Head hasa Brian crower 264 intake and 264 exhaust cams
Brian crower valve springs and titanium retainers
Valves are cut 3 angles
block has 0 miles OEM rebuild with new bearing and ARP studs/bolts all around
Cometic head gasket
Brand new s14 water pump ( got from dabz )
all this needs are the accesories and a gasket kit from nissan ( ebay has them for like 150 for the full set )
and ill give you what ever els is laying around in my garage
you can check my build thread in here for pics of BOTH built block and the other sr swap
heres a link
the car that will never run!
pics
built motor jaz
http://wtfitzac.blogspot.com/
drftx is online now   Reply With Quote
Old 08-06-2012, 08:42 AM   #2
kouki_pants's Avatar
text sent.
kouki_pants is offline   Reply With Quote
Old 08-06-2012, 09:46 AM   #3
CharCharXD's Avatar
pm me *interested*
CharCharXD is offline   Reply With Quote
Old 08-07-2012, 09:25 PM   #4
drftx's Avatar
bump someone get this so i can 1j it
Old 08-07-2012, 11:52 PM   #5
What are you looking to get for it ??
cchondro is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
