Old 11-14-2010, 07:24 PM   #1
S13 Sr20det eagle rods and HKS wastegate actuator
These parts are useless to me now. The rods are used and they came out of a s13 sr20. Price: 250.00.
Hks Adj Wastegate actuator. Missing 10mm lock nut(you can use any 10mm nut). I switch to a external wastegate and no longer need it. Price: 70.00
I accept paypal: You pay fees. Prices do not include shipping, you can email me at clever240_09@hotmail.com or send pm
Thanks
Had too many.....
clever240sx is offline
Old 11-15-2010, 12:42 PM   #2
240sx / Sr20 Performance partout!!
I bent some valves in my sr20 a couple days ago and that was my dd. Now i need to scrounge enough cash together to buy me another car. So im forced to sell most my 240sx parts and putting that project aside for the winter.
-Powder Coated FReddy intake manifold w/ s13 sr TB: 170.00
-Turbo kit. This turbo is bigger than a gt28 but smaller than a 30. It made over 450 on my setup on e85. Come with custom manifold, turbo, megan dump pipe, 38mm wastegate(with a tial 10 and 8 spring installed), dump tube for wg and all earls stainless braided lines: 1200.00!
- Custom GReddy Oil catch can with bigger air filter: 70.00
-Koyo Radiator(has a bad spot on the right side which gets covered up by fans, doesnt leak or effect cooling): 125.00
-Precision 1000cc top feed injectors(1000cc @ 43.5 psi , 1200cc @ 50psi) also comes with Mitsubishi resistor box: 250:00
-JGY Top feed fuel rail : 75.00
-AEM EMS for s13 Sr20det. Comes in original box, 3.5 bar map sensor, GM IAT, aem trigger wheel for cas and software: 920.00
-Used Sr20det EAGLE Rods : 250.00
-HKS Adj wastegate actuator: 70.00
If interested please email me at clever240_09@hotmail.com or send a pm!
Thanks!
Had too many.....
Old 11-15-2010, 08:56 PM   #3
Send a message via ICQ to Seraphim38
I am sort of new to 240sx so I don't know everything by sight yet. Is that an S13 redtop?
Are you selling:
-coolant tank (looks like a circuit sports version), I would be interested in it + the blue lines as long as it doesn't leak
-blue aftermarket pulleys (brand, asking price?)
I will need a top feed fuel rail soon for a standard S13 intake manifold. Would your JGY one work? I haven't heard the best feedback about their fuel rails.
Seraphim38 is offline
Old 11-15-2010, 11:19 PM   #4
Built S13 Sr20det
I just finished this swap in my 240sx. The other day i was driving it i heard a noise from the head so i turned the motor off and towed it home. I thought it was a knock so i took the oil pans off and the rods were fine. And i pulled the head tonight and as im taking it apart i come to realize that a rocker was not seated right. One of the caps that sits in the retainers had moved and the noise was coming from the rocker. After all this trouble it was just a simple fix. But now that i have the motor out i dont have a car to drive. Im very short on money because of this project and im just parting EVERYTHING out. No damage was done to the head.
The motor has the folowing done to it:
HKS 272 cams
- P2M rocker arm stoppers
- Brian Crower titanium valve springs and retainers
- Ported / Polished Head
- head was put together by Steigemeyer Machine Co.
- cometic metal headgasket
- Weisco pistons
- Eagle rods
- stock polished crank
- balanced rotating assembly
- Clevite bearings
- new rear main seal
- new oem oil pump
- baffled FReddy oil pan
- aftermarket pulleys for waterpump and alternator
You also get all componets(alternator, power steering pump, etc.)
If you want the intake manifold and turbo setup that will be extra.
Price : 2000.00!
Email me at clever240_09@hotmail.com or pm me.
Had too many.....
Old 11-16-2010, 09:36 AM   #5
Built 240sx Partout. *Mostly sr20*
I took my sr car apart because i thought there was a problem with the motor, come to realize it was a stupid easy fix. But im done for the year and parting everything out. Let me know what you need!
-SARD FPR : 55.00
Thanks!
Had too many.....
Old 11-16-2010, 04:31 PM   #6
did u run 450 on stock internals?
waylonmunoz2005 is offline
Old 11-16-2010, 06:45 PM   #7
drifter_for_life06's Avatar
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
interested in wastegate actuator....pm me
1992 RPS13: +.020" - 2871r - 264's - AEM EMS
drifter_for_life06 is offline
Old 11-16-2010, 07:13 PM   #8
Money sent for wastegate to your other email address. let me know when it ships.
nism014 is offline
Old 11-16-2010, 07:14 PM   #9
i just sent him money for the wastegate to his other email
nism014 is offline
Old 11-17-2010, 01:38 PM   #10
Low mileage S13 sr20 tranny :250.00
Apexi 2 Bar boost gauge: 45.00
Hks turbo timer with plug n play harness: 40.00
Greddy coolant temp gauge kit with Juran sender in samco hose and lower samco hose. Plug n play: 170.00
Greddy Oil pressure gauge. Plug n play. Needs new sende unit: 50.00
Innovate Lc-1 wideband. This is the whole kit, data logger, gague, newer sensor w/ only 500 miles, software, all wiring and different faces: 220.00!
Splitfire Coilpacks with plug n play harness with P2M grounding pack cover: 300.00
Meagn Racing brake boost cover for turbo, cut out for strut tower bar: 30.00
Tial Bov on greddy pipe. I used this on a greddy intake manifold: 200.00
Greddy Hot pipe and custom intake with filter for bottom mount turbo on sr20: 100.00
Spec Stage 3 unsprung clutch and pressure plate. Still has alot of life left! Used for 5k miles: 250.00
Greddy Fmic with all greddy piping and a real tial 50mm bov(v band) bov. Everything is in good condition. THe bottom of the fmic has a tiny dent, you cant see it and does not affect performance. Price: 650.00
Uploaded with ImageShack.us
Thanks!
Had too many.....
Old 11-17-2010, 07:54 PM   #11
Bump to the top
Had too many.....
Old 11-17-2010, 09:05 PM   #12
PM me with a price for the CS coolant overflow tank.
Tranman324 is offline
Old 11-17-2010, 09:39 PM   #13
Keeping that, sorry
Had too many.....
Old 11-17-2010, 10:25 PM   #14
slider2828's Avatar
What was wrong with the motor?
Turn and Burn!
slider2828 is offline
Old 11-18-2010, 11:04 AM   #15
Nothing is wrong with the motor. That also is for sale. 2000.00
Had too many.....
Old 11-18-2010, 11:39 AM   #16
Got the turbo timer?
two40guy is offline
Old 11-18-2010, 12:23 PM   #17
Pending sale on turbo timer. Ill post up by tomorrow if it sells or not
Had too many.....
Old 11-18-2010, 12:32 PM   #18
How much for the strut bar?
holys14 is offline
Old 11-18-2010, 12:59 PM   #19
Daggering's Avatar
How Much For The Turbo Timer Shipped To 11419
-Need 1jz Swap Part's For S13
-Need S15 Hood And Headlight's
Daggering is offline
Old 11-18-2010, 01:03 PM   #20
alright well if it dont sell i got dibs on it.
two40guy is offline
Old 11-18-2010, 01:16 PM   #21
oh yeah and is your radiator and hoses for sale too?
two40guy is offline
Old 11-18-2010, 03:52 PM   #22
Yep those are for sale also. The radiator for 125 and the hoses are in with the greddy coolant set. Look above for details
Had too many.....
Old 11-18-2010, 04:30 PM   #23
Winning
nissanfreak317's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Are you willing to split up the turbo kit? I would take everything except the turbo, lines, and o2 housing elbow thing... no need for em, LMK.
nissanfreak317 is offline
Old 11-18-2010, 07:29 PM   #24
jroy1234's Avatar
100 for freddy mani no tthrottle body
jroy1234 is offline
Old 11-18-2010, 07:36 PM   #25
alright man just let me know about that turbo timer ill paypal you cash right when i get word its still available
two40guy is offline
Old 11-18-2010, 08:04 PM   #26
Nissanfreak: how much are you willing to give for the stuff you want? Pm me an offer.
jroy1234: 150 shipped its yours w no tb
Two40guy: I will let you know by tomorrow
Had too many.....
Old 11-19-2010, 12:47 PM   #27
S13 Greddy Fmic, piping, and Tial bov
Up for sale is a Greddy Fmic with all greddy piping and a real tial 50mm bov(v band) bov. Everything is in good condition. THe bottom of the fmic has a tiny dent, you cant see it and does not affect performance. Price: 650.00
Had too many.....
Old 11-19-2010, 01:03 PM   #28
460
racerx2k1's Avatar
Thanks!
HKS 272 cams
- Weisco pistons
- Eagle rods
- Clevite bearings
- new oem oil pump
Price : 2000.00!
-SARD FPR : 55.00
Thanks!
Thanks!
Bump to the top
[/url]
Post multiple threads again, Marketplace privilege will be removed.
racerx2k1 is offline
SEO by vBSEO 3.6.0 PL2
