Old 02-21-2010, 09:15 PM   #1
1jzgte for sale
JZX90 1jzgte
- wiring harness w/ wuts not needed removed but not depinned from ecu plugs yet, jzx90 ecu and ignitor
- 2jzgte water pump
- turbo manifold w/ divided t4 to t3 adapter welded on(you can use T3 twinscroll turbo instead of T4), uses 40mm or 50mm wastegate, comes with new t3 divided metal gasket and the gaskets that came with the turbo manifold(using oem metal turbo manifold gasket
- new OEM Toyota front/rear main seals
- new Greddy timing belt
- spin on adapter for a oil filter relocation/ oil cooler setup w/ -8 fittings
- some misc. steel braided lines w/ earls hose clamps replacing some water lines.
- custom painted purple pearl black/white zebra striped valve covers
- will come with Aristo/ GS300 motor mounts
missing power steering pump. i might be able to get one. also missing stock injectors too.
no turbo/ wastegate either
$1300
located in SoCal, LA area
celicadrifter@sbcglobal.net
Garage BOSO
R. Rabe Body & Paint
CelicaDRIFTER is offline   Reply With Quote
Old 02-22-2010, 02:15 PM   #2
tht.1.s13's Avatar
dibbs.......pm me
tht.1.s13 is offline   Reply With Quote
Old 02-27-2010, 01:29 AM   #3
still for sale.
Garage BOSO
1jz, 2jz, s13, s14, turbo
SEO by vBSEO 3.6.0 PL2
