| For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
| | #1 |
| Leaky Injector | Sr20, Kade, AEM, Apexi, HKS and more Will Ship if needed. I am In Florida. SR20DET- NEW MSD 50LB top feed injectors w/plugs $275 NEW GM 3 bar map sensor $65 New GM intake air temp sensor w/ plug $30 ![]() JGY top feed fuel rail with -6 fittings $75 ![]() NEW -6 s/s braided line and assorted -6 fittings to upgrade fuel lines $180 ![]() ![]() NEW Apexi 86mm 1.1mm headgasket $185 ![]() NEW HKS 264 camshaft #22002-an007$200 ![]() ![]() Used walbro $50 HKS fuel rail adapter $old ![]() SR20DET GTI-R throttle body setup $350 ![]() AEM replacement wideband O2 sensor $90 ![]() Stock intake tube $20 Stock catch can $20 Power steering pump $old Divorced O2 turbo housing $old S13 KA24DE- Intake box $10 Fan and shroud $35 Starter $35 Alternator $35 Power steering pump $35 A/C compressor and bracket $45 Throttle body w/ TPS $35 M/T drive shaft $old Ignition coil $15 Injectors w/ Rail $50 Dual cam MAF $50 Single cam #10 M/T ECU $25 ![]() Suspension- S13 steering spacer $25 S13 Megan racing front tension rods $75 Subframe spacers $old Ebiach Sportline S14 front lowering springs $50 ![]() S13 Tein basics w/ front tein camber plates $old New S13/S14 camber plates $75 MISC- MOMO Corse steering wheel w/ ebay hub $old DIN gauge panel $20 A/C vent gauge panel $old boost, Oil pressure gauge $50 ![]() S13 Stock power mirrors $40 Trans Department Oil filter relocation fittings $25 Last edited by robertftw; 01-13-2010 at 07:49 PM.. Reason: update |
| Sponsored Links | |
| | #14 |
| 377 ![]() | 2 bump limit. You can start new thread in 3 days.
__________________ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
