Old 10-18-2009, 05:58 AM   #1
deukalionS14's Avatar
SR JWT tuned ECU for cheap!
Hey, I have a JWT tuned ECU for sale!!!!! it's tuned for 740cc inj and Z32 MAFS.
I ran it on my current set up which is S14 SR, 740cc inj, Z32 MAFS, 2871r .64, and HKS 256/264 cams. it made 315whp at 12psi with a good power band.
I switched to a stand alone set up so i have no more need for it.
I'm selling it for $400 O.B.O. i bought it for $650 so this is a steal!!!
either reply here or PM me for more details!!
April 5...the drifting shall begin...
deukalionS14 is offline   Reply With Quote
Old 10-18-2009, 09:49 AM   #2
that is the EXACT setup i will be running in my car in the spring. i have been thinking about sending my ecu out to jwt. why are you switching to standalone? what ecu code is it, and does it matter? ie, mine is a wc. anyways, i might be interested but don't they tune based on how much power you are trying to make? like, i am trying to push 18-19 psi on mine and make 350-380, would it still work without being re-tuned?
nissanfreak317 is offline   Reply With Quote
Old 10-19-2009, 05:37 AM   #3
I switched to a stand alone because i thought it would be better but it really wasnt a big difference. I only made 10whp more. Cody Ace is making 400whp on the same tune with a slightly different set up.
I also switched to a stand alone because i wanted to run e85 (which is gods gift to man kind lol i pulled more tq than hp on it)
their tunes are based on what the maf reads from what i understand so the boost level doesnt matter really aslong as there isnt any detonation.
they also tune for the type of fuel you use. i have it tuned for 91oct but you can run 93 with it no problem.
I recommend that you get on a dyno and raise your boost to make sure that you and the tuner can make sure there isnt any detonation at all and you can get your hp readings there. i ran 18psi no problem until my fuel pump crapped out.
I put down 315whp at 12psi with this tune. if you want a re-tune to dial things is more then its as simple as getting a datalog readout and sending it out to them. they dont charge much for the retune.
my ECU code is NA.
Old 10-19-2009, 10:47 AM   #4
I had a JWT ecu on my s13, i made 242whp with the T25 turbo at 12psi. I really loved it but also swithced to PFC due to the factory knock sensor picking up noise from my built motor and twin plate clutch.
180Sil is offline   Reply With Quote
Old 10-23-2009, 08:33 PM   #5
Buuuump! I know someone out there needs a reliable tune!!!
Old 11-02-2009, 04:41 PM   #6
it looks like the na and wc coded ecu's are different. found it here.
SR20DET WC ECU? Black? Red? Zenki Kouki?
mine is a red wc, lol old school.
anyways, can you post a pic of the side where the harness hooks up? maybe it would still work...?
thanks.
Old 11-02-2009, 05:59 PM   #7
+Waldo+'s Avatar
also interested. once said info is posted^
+Waldo+ is offline   Reply With Quote
SEO by vBSEO 3.3.0
