Old 10-12-2009, 04:53 AM   #1
importdude's Avatar
Send a message via AIM to importdude
S14 performance PART OUT Built KA-T 850cc Kazama,SUS, k's wing, se sideskirt,PLX M300
I have Decided to part ways with this car. MUST SELL ALL. Will be back in a few years:P
You Can call/txt me at
Im up late so anytime works
408-889-9384
Tony
Aol Aim= Sir owns j00
ENGINE
1.S14 BUILT Block,
a.Supertech 9.1 Comp, Eagle rods, ACL bearings, Felpro HG, Arp head studs, rebuilt head, .020 overbore – Complete Running Motor ~6000 miles on it
b.Will Hold ++ made 380whp 366wtq no leaking/ no blow by
- $2000
Still awaiting a stock motor to put in first
2. Top Mount Log Manifold T3 Flanged - $ 250
3. 3” V-band Ceramic coated down pipe. - $ 200
a.Bolts up to stock Cat/ length
b.Better than stock clearances
c. Recirculated dump pipe
4. 3” Megan Racing Test Pipe -$ 25
5. 3” Megan Racing Type II Exhaust Dual Tip Sounds perfect and looks good - $200
6. Garrett T3/T4 57 Trim .63AR 5 Bolt - $470
a.360 degree race bearing
b.Like new
7. Tial 38mm Wastegate 10.3 Psi Spring - $175
8. N62 MAF with pigtail - $110
9. Rywire S14>S13 Obd2 to Obd1 Conversion harness - $200
10. Greddy Type- S BOV Purple - $180
11. Power Precision/SARD 850cc Side Feed Injectors with clips - $380
12. XS Engineering FMIC +Powder coated Black FMIC piping - $350
a. Fmic Brackets, T-bolts, Couplers included
13. E-Mance Tuned S13 ECU - $ 215
a.Have 550cc N62, or 440cc N60, Or Sard 850cc N62 E85 Chips
14.PLX M-300 Wideband 02- $250
15.Ford Taurus 2 Speed Cooling Fan – $125
a.Comes with Wiring/Relay for Low and High Speed
b.High Speed has special 65amp Tyco Relay
c.Low Speed has 40/30amp Tyco Relay
16. Spec Clutch Stage 3 Sprung 6 puck ~10K Still meaty- $275
a. (Still in car)
17.BlackWerks S14 Full Dual Core aluminum Radiator - $180
a.3.5 inch thick
b.LIKE NEW used 1000 miles
c. (Still in car)
18.Autometer Sport Comp II white face, - $180
a.Boost, Water temp, Oil Pressure
b.All gauges are mint condition with all sensors and I will include my wiring, Features LED Bulbs Also Features Lighted RING
19. Animal House racing Vaccum Manifold- $25
20. Hallman Boost Controller - $70
SUSPENSION
Suspension Parts have only ~10,000 miles on them
1. Kazama Tie rod ends - $135
2. Tein Inner tie Rods - $70
3. SPL Tension Rods - $170
4. Kazama Rear Upper control Arms - $300
5. SPL blue Sub frame Collars - $80
6. Megan Racing S14 street Coilovers - $650
7. ST Front and Rear Sway Bar- $250
8. SPL s14 FRONT Blue Brake Lines- used for 5k- $35
9 .SPL s14 Rear Blue Brake Lines- BRAND NEW- $40
10. J30/Q45 calipers with bracket BRAND NEW PBR ceramic pads + 5 lug rotors redrilled
a.Rebuilt with 5k miles - $150
Wheels/Aero
1.Advan SA3R Red/Black - $1100
a.17x7 17x8 4x114 +35
b.Comes with all CAPS/rings/Removal tool/hubs
c.MINT NO CURBAGE NO DENTS NO BENDS
d.Has 2 inch clear-coat Scratch on 1 rim
2.S14 Kouki SE Side Skirts - $275
a.Professionally repainted Before install 10,000 miles
3.S14 JDM KOUKI K’s Wing - $300
built ka-t
importdude is offline   Reply With Quote
Old 10-12-2009, 05:17 AM   #2
You selling your (LED) AC unit control??
Eccentric Aces "Poppin Bottles.Flossin Models.Livin it up"!
EccentricAces is offline   Reply With Quote
Old 10-12-2009, 05:27 AM   #3
MannylovesLian's Avatar
test pipe please.
MannylovesLian is offline   Reply With Quote
Old 10-12-2009, 06:37 AM   #4
Walperstyle's Avatar
Send a message via MSN to Walperstyle
Who made the manifold?
I still need turbo, manifold, downpipe. quote shipping to Red Deer, Alberta, Canada?
KA-T ORG
Walperstyle is offline   Reply With Quote
Old 10-12-2009, 08:17 AM   #5
dibs on injectors!
Darkist 240sx is offline   Reply With Quote
Old 10-12-2009, 09:47 PM   #6
dRift_g0ddess's Avatar
Called about intercooler.. very interested. shipped to 91730?
~GirLs drift too ~
dRift_g0ddess is offline   Reply With Quote
Old 10-16-2009, 01:00 PM   #7
importdude's Avatar
Bump
bump
bump
bump
built ka-t
Old 10-22-2009, 08:55 AM   #8
turbo2nr's Avatar
Send a message via AIM to turbo2nr
$100 shipped for the kazama tie rod ends??
lmk pic if you have them please
97 s14 ka-t
turbo2nr is offline   Reply With Quote
Old 10-22-2009, 11:46 AM   #9
Fam0uZ's Avatar
how much for the signal lights shipped to 33178
Car: 1995 Nissan 240sx Se
Mods: Build Motor, 1600cc, AMS Manifold, 520WHP @ 22-23lb
Status: Rape Partyyy!!!
Fam0uZ is offline   Reply With Quote
Old 10-23-2009, 04:36 PM   #10
BUMP for so many quality parts which I need to get from you...
theconnect is offline   Reply With Quote
Old 10-25-2009, 04:06 PM   #11
importdude's Avatar
you should grab them :P i was looking on your build thread on ka-t
bump#2
built ka-t
Old 11-01-2009, 10:13 AM   #12
sileightyfreak's Avatar
Send a message via AIM to sileightyfreak Send a message via Yahoo to sileightyfreak Send a message via Skype™ to sileightyfreak
test pipe still available?
Originally Posted by Brian View Post
If I see you one day I'm gonna honk and throw a sticker out the car.
sileightyfreak is offline   Reply With Quote
SEO by vBSEO 3.3.0
