Old 07-20-2008, 07:45 PM   #1
Send a message via AIM to mjjstang
Huge s13 sr20det PARTOUT, quality tsuff, gt2871r
I HAVE DECIDED TO PART OUT. I AM UPDATING AS I GO WITH PRICES SO CHECK BACK OFTEN.
Car: dark red 91 s13 148k on the body, some areas such as half the interior and the hood among other locations look near perfect
Engine s13 sr20det
Parts that will be for sale
Set of gunmetal fno1rc (I know I should know this but I think they are 7 maybe 8 inch, the tires fit seemingly perfect on the rim, so yah, I will try to figure it out but maybe you guys would know) tires are falkan fk452 F: 235/40 R: kumho ecsta mx 245/40 probably 90-95 percent left.
4 lug
Pics show all of the bad spots, two have the slight curb rash, but I didnt even hit a curb so I dont know but it is not bad like you see on some. And there is a chip probably from a rock on the other one, I was devistated when I found this stuff out becasue only today did I see it, If you didnt know it was there and werent looking for it, you really wouldnt notice. I have had lot of compliments, Probably from people who didnt know how common they are but still they are awesome wheels and tires. I could never really spin with these.
I am looking for 725 plus ship
Blazt conzult cable (why doesn't everybody have one of these, I am confident that half of the threads in tech talk would disappear if everyone did have.) Comes with software, USB interface. SOLD
Enthalpy ECU #62 550cc z32 gt2871r .64 tune (I know the price is higher but I KNOW there is somebody out there with the same exact tune and your paying for an ecu and the already modified board, its all one unit and your saving a ton of money, this guy is well known and there are no surprises here. ECU NOT TUNED FOR AFTERMARKET CAMS but retunes are something like 125, CHEAP!!!!) SOLD
sr s13 main harness almost new, wired for s13 redtop 245 shipped
near new ignitor SOLD
s13 longblock, I have driven it about 1k miles, If I told you what the miles were on it, I would be lying to you, just like all the importers do anyway. SOLD
Sr power steering pump (comes with pulley but not the bracket, I have a modified KA bracket setup that is deff DIY but works and has worked well, I can include) SOLD
DOHC power steering lines, everything is pretty good, this is the line that wraps around by the pan, the short line that comes from the rack, the high pressure line, hoses from reservoir, and reservoir, 135 shipped
B&M short shifter 1k miles or less 175 shipped
Nismo gt shift knob almost new, it is this one. http://www.shopresponse.com/nismo_gt_shift_knob.jpg SOLD
Both upper and lower shift boot upper is fairly tattered but comes with the plastic pieces etc that are lusted after
kenwood radio I got for 75 bux the other day at ABC warehouse, its new basically I will figure out the part number later
AVC-R works perfect 355 shipped
gt2871r .64 garrett less than 1k miles 950 shipped SOLD
Taka Lines for said turbo, water/oil 140 shipped
ceramic coated stock exh manifold, if you want a good manifold that doesnt break, this is it. The pic shows that brown stuff, that is oil that burnt off of it before I found my dipstick was broke, which has been replaced, so the coating is till in tact, great manifold and looks better than stock55 shipped
vlsd 5 bolt axels, axels only, vlsd is shot SOLD
If anyone wants it, its a pretty good rear subframe, surface rust on a bit of it, all new energy suspension bushings, may part it out if you need certain pieces, stock arms, new upgraded bushings 100 miles.
blitz nurspec full catback exhaust, nearly new, less than 1k miles looking for 450 plus ship
3" downpipe project silvia, not ebay junk.
3" test pipe, project silvia, not ebay junk.
3" elbow, HKS type, paid 109 on a group deal while back, confident it is better quality than ebay.
Nearly new skinny 02 narrowband
Innovate lc-1 with wideband, NOT WORKING, I dont know if someone can fix, but it does not work, comes with bosch o2
Clutch and brake pedal and MC
Stainless damper delete clutch line from hard to slave fairly new, less than 1k
Sr20det transmission 5 speed, has ran strong, 2nd gear synchro is going I believe other than that it is nice
reinforced clutch pivot BRAND NEW
deatschwerks 550cc less than 500 miles 285 shipped
deatschwerks 740cc BRAND NEW with charts 385 shiipped
spare sr20det head, has some scoring that can be fixed at a machine shop, great if your doing a build and need work anyway. It has been slightly ported and polished, not fully but I am trying to get it flowed to make sure it hasnt been hurt by the job, mainly for sale for accessories such as hvla, rockers, shims, etc whatever you need its a full head EXCEPT cams
Decent valve cover, retains most of its lustre, only problem are some semi deep gashes in front, pics will follow later, but it is not bad, and gashes wont affect usability,
z32 maf
fully authentic greddy oil pan with baffels etc, less than 1k miles 285 shipped
2 gauge pillar pod with a few holes in it for mounting
water temp gauge autometer sport comp black face electric gauge 52mm SOLD
oil pressure gauge autometer sport comp black electric 52mm SOLD
boost gauge that reads a little low sport comp autometer 7 shipped (warning, I am only selling this for someone that wants a gauge for 7 dollars, It may need recal or something, but I know I lost major traction on "7"lbs now with AVCR readings, I was making 14 and not losing traction, so take it for what it is worth, it doesnt come with the nylon tube.
megan LED oil temperature gauge that is a week old electric full sweep.
center gauge bezel stainless 2 gauge with vent
BRAND NEW BC 264 int/exh cams SOLD
coil packs
Water temp gauge adapter that goes between upper hose, paid 44 from nissport, SOLD
oil pressure/temp adapter that goes in original sender for engine paid 53 from nissport, 35 shipped
BRAND NEW Greddy rocker stoppers SOLD
Brand new Valve cover main gasket (the one that goes around the outsider perimeter of the head)
JWT BRAND NEW valve guides
BRAND NEW valve Int/EX valve seals
BRAND NEW BC springs/titanium retainers SOLD
Walbro 255 less than 1k
Taurus 3.8 fan works great, even include some relays, project box, fuse holders
Sard adj FPR, from what I remember there are 2, standard and racing???? I have the standard with a water filed gauge and rail end hose adapter. SOLD with gauge
TYPE X Tails no scratches etc, trim is still primer black, and this has the all black center section. less than 500 miles Looks new. 400 plus ship
Manual transmission mount
Manual driveshaft
Throttle body stock manifold and 2 IACV
Water pump with almost zero miles, brand new for all intents and purposes, would be stripped of gasket sealer etc, was installed and flushed to FSM standards SOLD
BRAND NEW cometic 86 1mm gasket SOLD
BRAND NEW APEXI 86 1.1mm gasket SOLD
BRAND NEW ARP studs SOLD
New tokiko blues, less than 100 miles
ARC FMIC with ARC Black pipes and genuine couplers, this is a very nice kit and paid good money, It is top quality this thing is awesome and rare. it comes with the left side pipe that runs from the fuse box to the intake of the IC, and then from the exit of the IC to the TB, Upon closer inspection I can not say that the fins are perfect, they have some inconsistancies due to bugs, doesnt look like rocks really go up in there. Look at the pics, this thing is still pretty new. Fins are not going to be perfect, but a lot better than many others out there. 800 plus ship
Custom intake pipe that is untested with ac, but with minor mods clears ps and it has a bung for recirc. 3"
Genuine SSQV with recirc fitting SOLD
ENJUKU top quality Hot pipe with SSQV fitting and coupler SOLD
did I mention koyo copper? i forget which style it is, sr/ka, but it would use the real short pipe from the upper, and a longer pipe from the lower, so I guess it is for the SR, the ports are where they should be.
F/R strut tower bars, these were from a group buy and were deffinitely much better quality and price than Ebay. 120 shipped
EBAY catch can, has had no oil through it
Stock no holes coolant reservoir
Basically I have the whole car for partout, I will have pics but remember guys, no lowballing, I am in no hurry to sell, I want to recoup some of my losses here because like you can see most of this stuff is nearly new. I barely drive this thing and its time to move on. It really is hard to do this I have driven this car no more than 1k miles since I have dumped all this money into it, but I have had hundreds if not thousands of hours tinkering with it.
This is all I have time for right now, basically If the right offers come my way, I will start parting, I am very much about to do this, but I am looking for the right price, I have probably over 18k invested in this project, you can see most of my parts are quality, I did not discover ebay parts until recent, and still have not been happy with the quality on most. These are well cared for parts.
with the exception of a touchy cold start, this car runs like new, (2nd gear trouble as explained) My mother took a ride with me the other day and thought it drove like new, when I told her it was a 91 she laughed at me.
AK HI please inquire for additional rates.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline
Old 07-20-2008, 08:32 PM   #2
240love's Avatar
how much for the elbow shipped to ca?
240love is offline
Old 07-20-2008, 08:59 PM   #3
burnsauto's Avatar
interested in the oil pan if its genuine, and the 5 bolt axles.
Support Innovation.
WTB: ARC titanium spark plug cover for S13SR!!!!!!!
burnsauto is offline
Old 07-20-2008, 09:13 PM   #4
drftx's Avatar
Send a message via AIM to drftx
how much for the blitz nur spec picked up
drftx is offline
Old 07-20-2008, 09:30 PM   #5
QuickSpoolSR's Avatar
how much for the 2871
QuickSpoolSR is online now
Old 07-20-2008, 10:37 PM   #6
Yes it is genuine, I am going to answer everybody very soon with prices. And this is for everybody, when I say its a certain brand, it is genuine, really the only thing on here that is an "ebay" brand is the catch can, that I can think of. Everything else is GENUINE. nothing here is "xxxxx style"
mjjstang is offline
Old 07-21-2008, 06:49 AM   #7
SHIFT_*grind*'s Avatar
If the oil pressure and water temp gauges are electric, I'm definitely interested (would also be interested in the adapters if they're required to make the gauges work). If you do part out *please* let me know about these ASAP.
1993 SR 'Vert
Originally Posted by Springs1 View Post
I ONLY CONSENTED TO ONE COKE
My seller review thread
SHIFT_*grind* is offline
Old 07-21-2008, 07:16 AM   #8
wow my wish list
yunk_s14 is offline
Old 07-21-2008, 07:30 AM   #9
fromxtor's Avatar
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
got cash now for the turbo, and BC springs/retainers/cams
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is online now
Old 07-21-2008, 08:12 AM   #10
how much for oil pan and rocker arm stoppers
moses is offline
Old 07-21-2008, 10:23 AM   #11
interested in b and m and 550s located in 28303 pm me prices please
tkdae22 is offline
Old 07-22-2008, 02:13 AM   #12
How much are you looking to get for the ARP studs and the cometic head gasket shipped to 96814?
Also, what is wrong with the LC-1?
Thanks in advance!
Zhanshi is offline
Old 07-22-2008, 06:57 PM   #13
I Have updated my intentions as well as am starting to list prices, I think the easist way for me to do this, is find out what you guys are interested in, (keep posting/ PMing) and I will continue to post prices on these. Sorry if I have not been answering all posts and PM's but hope this form of listing helps, Since I am in no hurry to offload, I am not going to urgently post everything.
ASK me anything you need to, I will absolutely respond to your posts regarding questions about the items. Thank you very much.
Wideband is not connected to a gauge, it was used with laptop, one day while driving, the status light turned off, and I thought maybe it was the light, O2 sensor was not getting hot so no matter what, this o2 is probably shot since I have put a couple hundred miles of exhaust gasses through an unheated sensor.
mjjstang is offline
Old 07-22-2008, 07:00 PM   #14
They are electric, no fluids through any walls. These adapters were not cheap, prices posted.
mjjstang is offline
Old 07-22-2008, 07:04 PM   #15
240love's Avatar
elbow and front mount
240love is offline
Old 07-22-2008, 07:28 PM   #16
Going over past receipts, found out the test pipe/down pipe, are indeed project silvia, however the turbo elbow was a group buy "HKS STYLE" I dont know but this thing is great, anyway, I paid 105 for it. Throw me a PM offer.
mjjstang is offline
Old 07-22-2008, 08:18 PM   #17
240love's Avatar
hmmm..and the front mount?
240love is offline
Old 07-22-2008, 08:23 PM   #18
imnotmatt1189's Avatar
how much for the f/r strut bars shipped to 95212?
imnotmatt1189 is offline
Old 07-22-2008, 08:26 PM   #19
sorry, I posted it, but trying for 800 plus ship, Im seeing them new for nearly double, and also this is right around where others have sold theirs on ebay.
mjjstang is offline
Old 07-22-2008, 08:39 PM   #20
Hawaiian240's Avatar
s13
How much for the Sard FPR shipped to 29445?
Hawaiian240 is offline
Old 07-23-2008, 08:37 AM   #21
Send a message via AIM to Black240Ct
you have a pm
Black240Ct is offline
Old 07-23-2008, 10:45 AM   #22
Trader Rating: (81)
Feedback Score: 81 reviews
Send a message via AIM to besTint
would the
"BRAND NEW BC springs/titanium retainers 210 shipped"
work with my hks 264 cams?
http://squarespokes.com/
besTint is offline
Old 07-23-2008, 11:04 AM   #23
Originally Posted by besTint View Post
would the
Yes they would. Your cams are 10.5mm lift I believe, and the BC cams are something like 12mm. These springs would be great with your cams.
mjjstang is offline
Old 07-23-2008, 03:28 PM   #24
you gots PMz!
l2edken is offline
Old 07-23-2008, 04:17 PM   #25
OperationSr20's Avatar
Willing to ship exhaust to Nothern Illinois? Outside Chicago. How much are looking to get?
SHIFT_Patience
1989 Ka24De Hatchback:
12/20/2005 - 11/03/2006
1991 Ka24De Hatchback: 12/20/2006 - Current Day
OperationSr20 is offline
Old 07-24-2008, 02:36 AM   #26
shawn240sx's Avatar
is the ecu oem?
FONT="Century Gothic"][/FONT]
shawn240sx is offline
Old 07-24-2008, 03:40 AM   #27
MrFuel's Avatar
Send a message via AIM to MrFuel
Damn! that front mount is sexy
MrFuel is offline
Old 07-24-2008, 08:53 AM   #28
x240xdrifter's Avatar
Send a message via AIM to x240xdrifter
i'll give you 400 for those kouki lights shipped to 03855
SHIFT_passion
x240xdrifter is offline
Old 07-24-2008, 10:07 AM   #29
Originally Posted by shawn240sx View Post
is the ecu oem?
The ECU is OEM number 62. Enthalpy chipped it for 500, I have about 700 invested in it.
mjjstang is offline
Old 07-24-2008, 11:32 AM   #30
TUnity2's Avatar
how much for the Taurus fan setup?
TUnity2 is offline
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/sale-items/204007-huge-s13-sr20det-partout-quality-tsuff-gt2871r.html
Posted By For Type Date Hits
FS: PARTING OUT sr20det s13 lot of name brand - XceedSpeed This thread Refback 07-29-2008 10:05 AM 2
SEO by vBSEO 3.6.0 PL2
