Old 08-15-2012, 05:21 PM   #1
Reverse Lights
i've had several people tell me at red lights that they noticed my reverse lights are on while they're driving behind me. how do i fix this? what should i check?
i have a 1991 240sx coupe
thanks
Atill93 is offline   Reply With Quote
Old 08-16-2012, 01:58 AM   #2
Most likely you confused the neutral position switch and the reverse switch in your gearbox / wiring.
Old 08-17-2012, 01:32 PM   #3
i looked at it closer last night and i believe the wiring is switched between 4th gear and the reverse position. where can i find the gearbox wiring? I dont have a wiring diagram
Old 08-17-2012, 01:38 PM   #4
there are only 2 sensors : neutral and reverse . And they are just switches. just switch the plugs and you are done (chances are the sensors have been switched as i believe the plugs are not the same)
Old 08-17-2012, 01:50 PM   #5
okay, where are the sensors?
Old 08-18-2012, 04:14 PM   #6
Touge180's Avatar
They both should be on the side on the transmission.
Touge180 is offline   Reply With Quote
Old 08-18-2012, 08:21 PM   #7
thanks dude. i'll take a look at it tomorrow
Old 08-22-2012, 03:18 PM   #8
which wires do i need to switch to sort out my reverse lights?
Old 08-23-2012, 02:29 AM   #9
one closest to the engine
Bentleyness is offline   Reply With Quote
Old 08-25-2012, 09:57 PM   #10
simply switch the wires around?
its just the 4th gear and reverse position that i need to switch around
Old 08-25-2012, 10:21 PM   #11
R.I.P. David Mudge
zerodameaon's Avatar
There are more then two sensors. If you cant start your car after you swap these sensors around or can only do so in reverse that means that the issue is not in these sensors. You could have a short in the wiring for your reverse lights.
Here is a good pictures with labels.
Swap around 1 and 4 and see if that solves your issues.
EDIT: I reread your post and noticed they said its at red lights, is it only at reds? If so that for sure isn't those sensors and could be a short. That crappy bulb holder setup has a tendency to melt if you put to high wattage bulbs and all kinds of strange things happen.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
