Old 08-03-2012, 06:24 PM   #1
Egr tubing help
Hey, everyone. Name's Lance. Just got into the 240 scene with an 89 hatch. Got it with a broken stud in the block on the exhaust manifold. In trying to take the header off to get to the bottom right stud to drill it and hopefully easy out it out. The bung from the Egr valve to the header is rusted as a mug. Sprayed with pb blaster a bunch, tried vise grips, crescent wrench. Next try is going to be a pipe wrench. My question is do y'all have any better ideas/experiences? I'll take anything I can get right about now. Was also considering removing it all together. Read a few threads about it affecting how it runs, and othe people saying it doesn't change anything. Input?
1slowlance is offline   Reply With Quote
Old 08-04-2012, 03:52 AM   #2
Butcher240sx's Avatar
cut the pipe near the EGR valve with a hacksaw to get it apart. then use some rubber hose and clamps to hook it back together. You need an EGR. Leave it on.
Don't Mess With Texas
Butcher240sx is offline   Reply With Quote
Old 08-04-2012, 05:02 AM   #3
I didn't even think about hose clamps. I'll try to get it off with a pipe wrench today, and if that does t work, I may go your route. How much pressure is going through there? Rubber hose will hold that pressure?
Old 08-04-2012, 08:30 AM   #4
tapdeznutz's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
was thinking about doing this too but do you know what type/kind of hose to get that is heat resistant etc?
MY SALES THREAD
tapdeznutz is offline   Reply With Quote
Old 08-04-2012, 08:35 AM   #5
Well, the pipe wrench didn't work either. Just kept slipping off the nut. Not really sure what my next option is, other than finding a heat resistant tube?
Old 08-04-2012, 10:44 AM   #6
If where u live there is no emissions required, just remove ur egr, fab a block plate on the intake manifold
ka4life87 is offline   Reply With Quote
Old 08-06-2012, 02:11 AM   #7
Silicone hose is best. It doesn't really get that hot if you cut it near the intake. Any heater hose works. Leave the egr intact and functioning. Unless you have a blockage in the exhaust there isn't much pressure. Also when you slip the rubber over the the two ends of the egr tube almost touch.
Old 08-06-2012, 09:27 AM   #8
tapdeznutz's Avatar
Trader Rating: (40)
thanks. that is what i needed. yeah installed a header and the egr bung doesnt line up with the egr tube so i will be removing it and cutting it near the egr and re-attach with hose and coupling. thanks again.
MY SALES THREAD
Old 08-06-2012, 02:00 PM   #9
Dorifto Machine's Avatar
Yeah man, that EGR tube is nothing but a PITA , had the same exact issues. I brought the sawzall saw out and had to chop it. Then I blocked the egr with a Egr block kit. Car ran great, it actually idled way better.
Dorifto Machine is offline   Reply With Quote
Old 08-06-2012, 02:28 PM   #10
What kind of silicone hose are y'all talking about? Links?
Old 08-06-2012, 02:39 PM   #11
tapdeznutz's Avatar
Trader Rating: (40)
interesting. what about the vaccum lines. that go to the EGR, where do they route/re-route to?
MY SALES THREAD
Old 08-06-2012, 02:52 PM   #12
Its hard to explain without you staring right at it but you will see the the lines that once went to the EGR will be able to be recirculated and or plugged. Its not hard at all. You cant mess it up unless you just leave a vacuum leak open.
Old 08-06-2012, 03:01 PM   #13
tapdeznutz's Avatar
Trader Rating: (40)
cool thanks. Freaken California SMOG laws make me crazy
MY SALES THREAD
Old 08-06-2012, 03:28 PM   #14
Don't remove the egr unless you retune your ecu. Leave it on functioning. If his idle got better its because something was wrong with the egr. Factory put it there and tuned for it. All you get is 2hp worse fuel economy and less longevity of your engine. Also won't pass visual or emissions inspection.
I take pride in passing a sniffer test. These aren't old muscle cars, they should run clean.
Old 08-06-2012, 03:47 PM   #15
Trader Rating: (77)
Feedback Score: 77 reviews
^Lol. If your state doesn't have emissions testing then delete that shit. It's garbage. You don't need to retune for it either.
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 08-06-2012, 03:50 PM   #16
tapdeznutz's Avatar
Trader Rating: (40)
well once i pass smog i want to take it out and save for next smog session same goes for the test pipe
MY SALES THREAD
Old 08-06-2012, 04:02 PM   #17
Trader Rating: (77)
Invest in an egr block off plate and an egr plug then. The block off plate can be found cheap on ebay and you can buy an egr plug from Nissan. Yes the dealership. The parts guy I dealt with was a douche and wanted to go on about how it's illegal blah blah blah. Tell them it's for a race car.
Old 08-06-2012, 04:02 PM   #18
laurentj23's Avatar
Any idea where i can get that hose?
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 08-06-2012, 04:16 PM   #19
tapdeznutz's Avatar
Trader Rating: (40)
agreed. i already got a egr block in the header. and i had to ask for it by part number as the dealership is reluctant to help you with these type of parts. am exactly want to block off egr once smog is taken care of.
as for the hose i was going to go with McMaster- Carr.com for the hose i just need to measure what the inner diameter (ID) of the egr tube is so i can order the hose and clamps i need.
MY SALES THREAD
Old 08-06-2012, 05:58 PM   #20
Before calling the egr garbage I would do a little research on what it does. Not from other rice forums, but actual engineering. There is no benefit to removing it on a daily driver. But there are drawbacks. I prefer not to listen to advice from people younger than the car they are talking about. Just a thought.
Old 08-06-2012, 06:01 PM   #21
tapdeznutz's Avatar
Trader Rating: (40)
nice. well how about can you give me your thoughts on it then. you are qualified at least, age while of course. no pun intended i am always open to learn what i do not know.
MY SALES THREAD
Old 08-06-2012, 06:55 PM   #22
I'm pretty sure the od of the tube is 1/2". Which of those hoses from that site were you going with? I read the neoprene tubing only stands up to 200F. That doesn't seem like enough.
Old 08-06-2012, 07:26 PM   #23
Trader Rating: (77)
That's your "preference." I own and work on cars older than you as well. Age is irrelevant when you know what you're talking about. EGR's leak and fail over time. Care to tell OP how much they are to replace? I won't go as far as to call you an old man but you might be on the wrong forums. Should have bought a Prius if thats truly your concern. My KA has no emissions left, it's turbocharged and still gets over 20mpg. Just sayin.
Old 08-06-2012, 07:31 PM   #24
Gasoline burning engines operate by mixing fuel with air, compressing it inside the cylinder, and igniting it with the spark plug. Ideally gasoline burns oxygen. But air contains 70 percent nitrogen and has traces of other gases. Nitrogen is fairly inert and doesn't like to combine with the gasoline. But as combustion chamber temperatures climb, nitrogen is far more likely to combine with oxygen and form nitrous oxides, also known as NOx. Nitrous oxides are a major component of urban air pollution. Gasoline, too, burns best when combined with air at a ratio of 14.7 air to 1 fuel. But leaner combinations improve fuel economy. The problem is that when gasoline is burned lean it tends to knock. Knock greatly reduces thermal efficiency and can damage the engine if allowed to continue. While there are practical limits to how lean an engine can be forced to run, it can be improved somewhat with lower combustion chamber temperatures. By lowering combustion chamber temperatures, pollution is reduced and fuel economy improved. Performance will be sacrificed somewhat, but that is a necessary price for air quality.
Combustion Chamber Temperature
There are two ways to decrease combustion chamber temperatures. The first is to reduce compression ratio. Compression ratio is the amount of compression provided by the cylinder. But significantly reducing this factor to less than 8:1 or so drastically reduces both performance and efficiency. Another way to reduce combustion chamber temperature is to add something inert to the air-fuel charge. Something that won't burn. Fortunately every car and truck has a ready made supply of inert gas--the exhaust. Surprisingly, adding exhaust to the inlet air charge actually decreases maximum combustion chamber temperature. This seems counter-intuitive since the exhaust is hot. However, when it exits the cylinder it is cooler than the maximum combustion chamber temperature. So by pumping it back into the combustion chamber it will not burn again and absorbs heat.
The EGR Valve
EGR stands for Exhaust Gas Recirculation. The valve directs a small portion of exhaust gasses back into the inlet air charge and lowers the maximum temperature of the burning fuel. The valve makes sure that the EGR system is off at idle, where it would lead to erratic and loping idle, and at peak power, since adding exhaust gasses robs power from the engine.
Other Benefits
Besides reducing pollution and lowering combustion chamber temperature, recirculating exhaust also has the effect of lowering pumping losses. Pumping losses are the work the engine must do to pump the inlet air past the throttle plate. Since EGR lowers power the throttle must be opened wider for a give desired power, meaning the throttle opening is wider so the engine doesn't have to work as hard to inhale the air. Moreover, with a lower combustion chamber temperature there is less heat loss to the metal walls of the cylinder, the piston, and the cylinder head so that more internal heat is retained to be converted into mechanical work.
History of EGR
The first EGR systems in the early 1970s operated strictly on manifold vacuum. They had a huge impact on performance, driveability and reliability. Many owners simply removed them and modified the carburetors to prevent running lean. Slightly later systems added electronic controls that improved both performance and reliability but problems continued and the systems, while mandated by Federal Law, were unpopular with drivers. Some foreign manufacturers opted to make their engines very small and, since they produced so little exhaust gas, were able to eliminate the EGR system completely. This move helped them gain a foothold in the American market. The system continued to evolve however, and combined with modern computer-controlled engine management systems, have no impact on driveability at all, and in fact provide a significant benefit both to controlling pollution and to improving fuel economy.
Old 08-06-2012, 07:36 PM   #25
The egr isn't usually the cheapest part to replace, but aside from the diaphragm tearing and failing it can usually be cleaned. My preference is to leave mine on and functioning.
Old 08-06-2012, 07:44 PM   #26
Trader Rating: (77)
Old 08-06-2012, 07:45 PM   #27
Trader Rating: (77)
If you feel like dicking with it for the rest of your 240sx ownership that's your decision. I'm giving OP the general consensus.
Old 08-06-2012, 08:05 PM   #28
"General consensus" is purely subjective to who you are around. Talk to engineers and the mechanics at the shops I have worked for and you might get a different answer. It really doesn't take much "dicking with". Just basic knowledge of emissions systems and basic mechanical ability. How about a new argument. Carb vs EFI. Or engines need backpressure to make low end torque. And yes copy and paste is great for saving time.
Old 08-06-2012, 08:17 PM   #29
Trader Rating: (77)
I'm referring to these cars. I've worked for a shop as well. Willis Auto Campus to be exact. Google it. It's also not just who you're around. This is information that's been out there for years. Why don't you search this here forum and tell me how many threads you can find on keeping the egr vs deleting it.
Old 08-06-2012, 09:20 PM   #30
tapdeznutz's Avatar
Trader Rating: (40)
i do value everyone taking the time and giving there input/experience. its not worth an argument over. so lets agree to dis-agree
anyways i just measured the ID of my ka24E egr tube and i believe i measured approx. 3/4". if you look on mcmaster-car search silicone tubes or silicone hoses and narrow search for max temp rating. i will try my lucky this weekend at the smog man and see what happens. i did do the "push on egr" and engine did start to stumble but my damn CEL in still on. i hate old cars...
MY SALES THREAD
SEO by vBSEO 3.6.0 PL2
