Old 07-21-2012, 04:06 PM   #1
s13 vibration in 2nd-3rd gears
bought my first s13 last night. Biggest concern at the moment is that she vibrates in 2nd and sometimes 3rd gear. It feels as if it originates from the rear end, but that might just be me. (the vibration is similar when you shift to early and the motor boggs down)
OneManDeep is offline   Reply With Quote
Old 07-22-2012, 06:39 PM   #2
found it its not gear specific, it happens almost promptly at 30-40 mph. ANY advice?
Old 07-22-2012, 11:30 PM   #3
cotbu's Avatar
get an alignment!
or new tires!
or both!
Check rotors and brakes as well.
Old 07-23-2012, 12:01 AM   #4
Tires are new so i will begin with the brakes/rotors since i just found that they vibe when applied. any reasonable recommendations?
Old 07-23-2012, 01:47 AM   #5
Depends on what you plan doing with that 13.
Z32 brake system is bolt on and provide a nice upgrade, but you need bigger wheels than oem ones.
If you are going to race it, i saw a groupbuy for a complete wilwood brake system, front and rear, with 2 piece rotors and aluminium forged calipers on NRR forums ( i think it was ). The GB is over but i guess you can get the parts from the guy anyway. Of course, this is not the same price.
If you have the 1st gen with 253mm front rotors, you might want to upgrade to the 2nd gen 280mm rotors. You will need rotors and brake caliper bracket to upgrade.
I am positive there are other possibilities, but i think these are the most balanced you could use. trackdays / race > wilwood front & rear, hard driving > Z32 + better pads front & rear , normal driving > keep oem (brembo rotors are nice)
Old 07-23-2012, 01:50 AM   #6
jesse_s13's Avatar
Make sure the Balancing on the wheels are good before you buy rotors.
jesse_s13 is offline   Reply With Quote
Old 07-23-2012, 04:43 PM   #7
not looking for a huge mod, i have no intention on racing/tracking/drifting. just want a nice setup with low brakedust, good price, and hopefully longevity. I will also begin searching the forums on brake setups. Thanks in advance for any and all advice yall have for me
Old 07-23-2012, 04:50 PM   #8
WIKID S4TEEN's Avatar
Also can be the support bearing for drive shaft.
if so, go with a one piece drive shaft.
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 07-23-2012, 04:53 PM   #9
why change the entire shaft instead of just the bearing? Im asking because i suspected the drive shaft support may be the cause, and iv started pricing/hunting for one.
And also what are the pros/cons & cost of a 1pc shaft?
Old 07-27-2012, 04:45 PM   #10
Its a waste I replaced center carrier bearing , but the universal joints cant be replaced. And I still got vibration similiar to yours , starts around 30 - 35 mph. Also I had bad trans mount , so I upgraded to the megans , motor and trans mounts seems to have help but not gone , Im sure its the Uni joint which did have a resistance at a certain point.
1 piece shaft is my next step and sure it will solve it.
Prozac is offline   Reply With Quote
Old 07-27-2012, 10:59 PM   #11
thanks for the response. Have you found Any reasonably priced shafts?
Old 08-25-2012, 10:31 AM   #12
hey just wanted to update.. the problem was the driveshaft. i bought a one piece and acceleration is excellent now. no vibration no hesitation
Old 08-25-2012, 10:01 PM   #13
great thread. i've been experiencing similar symptoms in my s13 coupe that i just bought a few weeks. i didnt know if it was normal and i've kinda gotten used to it haha but its definitely still there. where did you get your one piece driveshaft from?
Atill93 is offline   Reply With Quote
s13 240sx
SEO by vBSEO 3.6.0 PL2
