Old 07-02-2012, 04:13 PM   #1
JacksonBrown's Avatar
SR Which Fan To Use?
Setup:
Chassis:
S14
Motor: S14 SR20det
Radiator: Koyo S14 SR20det
Shroud: S14 SR20det
Clutch Fan: RB25det
For 4 years I was running an aftermarket electric fan on my radiator that was ziptied into the core. Part of the core failed, so instead of welding that part off, I purchased a new Koyo. This time I didn't re-install the aftermarket electric fan because I didn't want to risk it compromising the core over time (which is what I think was the culprit the first time around).
So, the question is:
Which fan, KA24de or SR, can I run on the radiator that bolts onto it without having to run zipties into the radiator?
Thanks in advance.
JacksonBrown is offline   Reply With Quote
Old 07-02-2012, 04:33 PM   #2
zero.counter's Avatar
Send a message via AIM to zero.counter
KA Stock clutch fan is fine (research as this has been debated quite a few times in the last decade)
If you decide to go back to electric, the FAL model 345 fits the Koyo.
345 Nissan 240SX Dual Electric Fan
Been running on mine since 2005. Solder/heat shrink is of the utmost importance.
zero.counter is offline   Reply With Quote
Old 07-02-2012, 09:10 PM   #3
Thanks for the info - yeah, I've seen the debate back and forth over the years but never paid it much mind since my electric fan was ostensibly functioning correctly. My question/concern with running an FAL set up is that, at high speeds/freeway, the fans getting in the way of the natural air flow to the radiator. I suppose I could put a switch on it to turn off though. Hmmmm..
SEO by vBSEO 3.6.0 PL2
