Old 07-02-2012, 03:02 PM   #1
mr2gons14's Avatar
sr20 pump gas pedal to start
Hey yall i searched and nothin really whats happenin to me. I got a redtop sr and the problem i know of right now is my intake mani has a small crack on the middle of the flange that connects to the head. That resulted in a blown gasket also my iacv had a ripped gasket i fixed with some gasket maker though when i was threading on the screw the back piece of the flange broke off....while hand tightening lol. I got a new intake mani on the way so not a problem. I may be answering my own question but anyone had something like this happen? it only starts when u pump the gas pedal then once it warms up it drives fine. any input
zilvia.net/f/cars-sale/517359-95-240sx-sr20-swap-uras-greddy-apexi-ect.html
mr2gons14 is offline   Reply With Quote
Old 07-02-2012, 08:47 PM   #2
mr2gons14's Avatar
anyone at all?
Old 07-03-2012, 12:54 PM   #3
mr2gons14's Avatar
still lookin for some input
Old 07-09-2012, 05:09 PM   #4
mr2gons14's Avatar
hey still need some input someone has to of had this issue happen before swapped out manis and it fixed a few issues but not the starting issue i still have to pump the gas peddal to start
Old 07-09-2012, 07:36 PM   #5
ultimateirving's Avatar
is ur iacv still busted? fix that and u will be able to start easier, you dont want any vac leaks it wreaks havoc on SRs
Sr20det-e85 - 2871r - Ksport coilovers.
Old 07-09-2012, 10:10 PM   #6
mr2gons14's Avatar
iacv is good when i said new mani it included everything could it possibly be one screw from mani to block is partially stripped but no leaks from there and i dont think i got any leaks anywhere else. I gotta test the rest of it but no irradic idle or anythin just gotta pump gas to start
Old 07-10-2012, 07:54 PM   #7
mr2gons14's Avatar
o no dice so far starts up perfectly fine if im pumpin the peddal anyone thinkin tps or something I dont see it being my cas but you never know im just lookin for some direction here
Old 07-10-2012, 09:52 PM   #8
Check start signal fuse in fuse box in the car. Also check the orange wire i think going to the ecu. If the fuse is bad or a short in that wire it will be hard to start but run fine after. Had similar problem on my blacktop s13.
mobmotorsports2002 is offline   Reply With Quote
Old 07-11-2012, 12:37 AM   #9
mr2gons14's Avatar
funny I just messed with my tps and it fired right up tomorrow if the problem persists ill go ahead and check that out
Old 08-20-2012, 11:50 AM   #10
Nickys13's Avatar
so was the tps your problem?
Nickys13 is offline   Reply With Quote
Old 08-20-2012, 06:20 PM   #11
mr2gons14's Avatar
reset tps and timing then reseated intake mani fixed the problem
SEO by vBSEO 3.6.0 PL2
