Old 06-24-2012, 12:50 PM   #1
heating...once more!
Okay so i replaced the HG on my RB20det replaced the intake gasket. Did what i thought was bleeding the water system but i still seem to get to 210 after about 20mins of driving. Please someone help me fix my RB by telling me what i may have not done to fix my issue.
OhSnapS14 is offline   Reply With Quote
Old 06-24-2012, 01:56 PM   #2
SR/RB Guru
Sileighty_85's Avatar
Need stronger fans? Fans blowing the correct direction?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-24-2012, 02:14 PM   #3
They seem to be blowing on high just fine and they are sucking fans not pushing. thats the way the guy before me had them set up. Can a heater core issue be a problem?
Old 06-24-2012, 07:38 PM   #4
really can no one else help?!
Old 06-24-2012, 07:40 PM   #5
SR/RB Guru
no a heater core would not be the issue. If your heater is not working then you still have Air in the system
後輪駆動車1番
1986 SR86 - 200ish
Old 06-24-2012, 08:13 PM   #6
whats the best way to bleed the coolant system, raise up the front end? also when i look in the radiator the water isnt moving from side to side. =/
Old 06-24-2012, 08:22 PM   #7
SR/RB Guru
open bleeder screw fill up coolant, raise front end, turn on engine, turn on heater wait and watch temps
後輪駆動車1番
1986 SR86 - 200ish
Old 06-24-2012, 08:26 PM   #8
Butcher240sx's Avatar
Make sure you have a new thermostat installed with the button at 12 o clock.
Don't Mess With Texas
Butcher240sx is offline   Reply With Quote
Old 06-24-2012, 08:36 PM   #9
ive take out the thermostat completely cause of the issues ive been having with it and also i bypassed the heater core today to see if that was it. was told to by a friend. ill put that back together but the custom intake plenum i havent a clue where the bleeder screw is. and its not on the radiator.
Old 06-24-2012, 09:42 PM   #10
Did you buy a new rad cap? And have the head surfaced when you did the HG?
Old 06-24-2012, 09:49 PM   #11
No the rad cap is the same and it was wiz wheeled not resurfaced. Did a dye test and it was fine. also the compression came back good and I'm losing no coolant so let's rule out hg. i found something saying that the RBs get air locked easily so im gunna try that tomorrow.
Old 06-25-2012, 04:57 PM   #12
Start with a new cap. It's cheap. If that fixes it put your thermostat back in. Bleed well. How are you measuring temp? Aftermarket gauge? I've been working on a Saturn this week that sits at 210 pretty quick. The Efan doesn't even come on until about 225*
Old 06-25-2012, 08:26 PM   #13
SR/RB Guru
^^ Thats pretty damn hot guy.
My RB runs around 180-188*
後輪駆動車1番
1986 SR86 - 200ish
Old 06-25-2012, 09:53 PM   #14
Yeah , I thought so too. When the fan finally comes on the temp drops to 200 and the fan turns back off.
Old 06-25-2012, 10:27 PM   #15
SR/RB Guru
Thought you were referring to an RB Engine...
Every engine is different
後輪駆動車1番
1986 SR86 - 200ish
Old 06-27-2012, 02:23 AM   #16
yah, i bleed it and it seems to be running better about 210 on avg today just puttering around. what kinda temps do you get when you drift?
SEO by vBSEO 3.6.0 PL2
