Old 06-14-2012, 12:21 PM   #1
Flicktitty's Avatar
Send a message via AIM to Flicktitty
Odd brake fluid leak
I installed some Q45 front calipers/rotors/lines a couple weeks ago. bleed the brakes filled the master cylinder. pedal was ok, then i noticed the fluid level went down. I found the caliper was leaking bought a new one. and it was fine, I went ahead and re-bleed all the brakes pedal was fine. went out had lunch came back and the reservoir was about half empty. brake pedal was still firm. Then i refilled it and it hasen't gone down at all.
*NOTE - I HAVEN'T DRIVEN THE CAR* it's just leaked when it sits in the garage. No fluid on the wheels, or calipers. no leaks on the hard lines. the rear lines are dry. and the new front stainless lines are dry. all the calipers check out good.
there was a LITTLE fluid under the master cylinder and the frame rail but not much, no where near as much fluid as was lost. Just wondering what else to check? I ordered a new master cyl. and reservoir but just looking for other thoughts.
Thanks, Nick
1989 240sx SE Coupe, 19k Original miles, 2JZGTE, PT6266,Fuel System, AEM V2, Sound Performance Tuned
www.Wi240sx.com | http://flicktitty.tumblr.com
Flicktitty is offline   Reply With Quote
Old 06-14-2012, 12:34 PM   #2
Trader Rating: (26)
Feedback Score: 26 reviews
Possibly leaking out of the back of the MC. Did you tighten up the lines from the MC? it has to be going somewhere, it doesn't just disappear. Notice any fluid on the bottom of the booster?
VVL S14 in the works...
Old 06-14-2012, 12:49 PM   #3
Flicktitty's Avatar
there is very little. but i couldn't tell if thats from spilling the fluid or not. i have since wiped it off and nothing has been back. Would it leak out the back of the MC without the brake pedal being pressed?
Old 06-14-2012, 03:40 PM   #4
Trader Rating: (26)
If the internal seals are bad enough, yes it can seep out. I have a similiar issue, however, I have a completely different setup than you. Wilwood 4pot Superlites and Z32 rears. I noticed my fluid running skinny in the resevoir a few times. I found a small leak at one of the rear calipers, however I think it only leaks when pressure is applied to the system(inbetween caliper halves).
Brake fluid is very corrosive, if it's not cleaned off a painted surface fast enough it will eat down to bare metal. Keep that in mind, unless you don't care too much how your engine bay looks.
Old 06-15-2012, 06:36 PM   #5
Back of the master leaking into the booster?
project-c2 is online now   Reply With Quote
SEO by vBSEO 3.6.0 PL2
