Old 06-12-2012, 06:24 PM   #1
Isis tension rod install. simple question
why is the bump stop in the way? i took off the nuts from the lca side and then unbolted the radiator support side. that was easy. now i can't get the lca side to come out of the lca because the bump stop is in the way. anyone have any advice that makes sense? i want the bump stop...
sicknamehere is offline   Reply With Quote
Old 06-13-2012, 11:53 AM   #2
no one has done this before? it's not like this is a crazy mod, i just need to know how to actually slide the part out
Old 06-13-2012, 04:02 PM   #3
Promise Land's Avatar
I have them on mine, but I don't understand your question. Mine came right out. I have the NISMO brace, so maybe that makes it different?
Promise Land is offline   Reply With Quote
Old 06-13-2012, 07:27 PM   #4
the only thing i can think of is maybe you slide the bushing end down in order to get the lca end out. which i can't do because my radiator support is a little bent.
Old 06-13-2012, 07:37 PM   #5
eek
Take a picture and show us your problem.
eek is offline   Reply With Quote
Old 06-14-2012, 01:36 PM   #6
On the lower control arm, the bumpstop (think thats what its called) for the tie rod end, the upper ridge keeps us from pulling the tension rod out where it bolts to the FLCA.
We read all the guides and nothing mentioned that. Probably a simple answer.
KendallH is offline   Reply With Quote
Old 06-15-2012, 09:50 PM   #7
jabless13's Avatar
IIRC mine came into contact with it, but i just whacked the shit out of it with a BFH until it came out.
jabless13 is offline   Reply With Quote
Old 06-18-2012, 11:24 AM   #8
figured it out. the radiator bracket or whatever it's called that bolts to the bushing part of the tension rod was bent. so i had to pry it open to allow the tension rod to fall out of it. the part where the rod bolts to the lca can only come out if you pull the bushing part down. so, unbolt the tension rod. let the bushing side fall down. keep it lower than the lca and you should have no problem taking the 2 bolts out of the lca.
SEO by vBSEO 3.6.0 PL2
