Old 06-12-2012, 04:46 PM   #1
Stuck Clutch Pedal?! [Pictures]
Well today I was at the light and my clutch got stuck in. I tried pumping it a bunch, and even pulling it out, but still nothing.
Fluids are cherry, so I looked under dash and saw this;
That bracket with the cotter pin, is broken off from the rest. And it's supposed to be around the rod, with the nut securing it down.
Could this be a problem? I've never delt with this kind of problem before, but I'm assuming this could be the cause?
If so, were could I find this bracket? Or would I need a whole
New clutch pedal assembly?
Thanks in advance !!
Tedskiii is offline   Reply With Quote
Old 06-12-2012, 04:50 PM   #2
Get another clutch mc and the bad bracket will be on the new one or try the junk yard
jdmfan13 is offline   Reply With Quote
Old 06-12-2012, 05:00 PM   #3
adrians_s13's Avatar
yeah, if i recall correctly, new MC's come with the bracket and cotter pin
http://farm2.static.flickr.com/1288/886320359_37461ccbf3.jpg
Old 06-12-2012, 05:30 PM   #4
I </3 VA
fliprayzin240sx's Avatar
You can buy the U bracket from the dealer. I've had to replace a couple of these already. I usually put a wide washer on the other side of the bracket, on the shaft side, to help even out the load on the bracket when you press the pedal down.
CLICK HERE!!!
FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate
SEO by vBSEO 3.6.0 PL2
