Old 06-01-2012, 02:17 PM   #1
Jhester's Avatar
Send a message via AIM to Jhester Send a message via Yahoo to Jhester
s13 Tire Woes
Hey guys, Im flying through front tires. take a look at the pics below , The left pic was 4 weeks ago. Right pic was today. Ive had an alignment in last 6 mos. What do you guys think on the tire wear on the left pic? Insights are welcome.
Jhester is offline   Reply With Quote
Old 06-01-2012, 02:18 PM   #2
Jhester's Avatar
Better view of odd wear pattern.
Old 06-01-2012, 05:59 PM   #3
I </3 VA
fliprayzin240sx's Avatar
Just daily driven? Toe must be completely fucked...you checked your suspension to see if you got anything loose, busted tie rod end, lower control arm bushing, tension rod. If all that checks out, get a measuring tape and measure across the back and front of the tires at about the same height across. If your toe is good, it should be fairly even, meaning they are perfectly parralel.
CLICK HERE!!!
FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate
Old 06-01-2012, 06:01 PM   #4
Banana_Cute's Avatar
every turn isnt for drifting, Fanboy. LOL
j/k. idk.
Simplicity is the key to brilliance
Banana_Cute is offline   Reply With Quote
Old 06-01-2012, 06:08 PM   #5
I </3 VA
j/k. idk.
Shit, thats the first thing I thought, but those are his front tires...I'm almost willing to bet he got something broke that changed his alignment. There's no way an alignment shop could fuck your alignment up that bad. Unless they hate you and wanted to kill you.
But hey, look at the bright side, his camber is good since they wore out evenly.
CLICK HERE!!!
Old 06-01-2012, 06:10 PM   #6
Unda unda unda!!!! Hahahhaha
Old 06-01-2012, 06:11 PM   #7
That's negative toe destroying the outside of the tire! 240s call for just a touch of positive toe, get it aligned again and make sure the shop gives you a printout of the alignment specs before and after. This of course assuming all the front suspension and steering components are tight and undamaged.
KA-Life86 is offline   Reply With Quote
Old 06-01-2012, 06:27 PM   #8
Post pic of your alignment sheet that you got
PureRush is online now   Reply With Quote
Old 06-01-2012, 08:24 PM   #9
That's some massive toe out. Also what tire pressure you setting to?
project-c2 is offline   Reply With Quote
Old 06-01-2012, 08:39 PM   #10
Eraism's Avatar
Does it drive funny? Steering feel sloppy? drives straight?
lurk lurk lurk
Eraism is offline   Reply With Quote
Old 06-02-2012, 07:58 AM   #11
Jhester's Avatar
The alignment shop didn't give a sheet ( pun unintended ) It is daily driven with 32 psi. Eraism , The front end is sloppy. Feels like the rack is shifting . I suspect the energy suspension steering rack bushings aren't adequate and ordered the nismo bushings. After the bushing install I'll get re aligned with before and after sheets.
Old 06-02-2012, 01:58 PM   #12
looks like not negative camber but positive camber with a bad toe?
h2v7 is offline   Reply With Quote
Old 06-02-2012, 02:26 PM   #13
Jhester's Avatar
Camber is -1.5 front. I agree on bad toe. I just replaced the shitty energy suspension rack bushings with nismos and the rack no longer moves but It feels like toe is off . The beauty of converted manual r&p.
0/32 of tread and 72 degrees outside. No worries...
Old 06-02-2012, 07:17 PM   #14
RyanS13's Avatar
It's definitely your toe. when you turn the wheel straight, you can't see the toe off?
RyanS13 is offline   Reply With Quote
Old 06-02-2012, 07:36 PM   #15
Obivously he did an AWD conversion and has been spinnin em everywhere lol
The_Creeper is offline   Reply With Quote
Old 06-02-2012, 08:02 PM   #16
Jhester's Avatar
ryans13, you have any idea how difficult it would be to "eye" bad toe? we are talking about .02-1.5 degrees . and the_creeper- who said awd? im all fwd lol
SEO by vBSEO 3.6.0 PL2
