Old 05-26-2012, 03:43 PM   #1
S13 brake problem?
Okay so I changed the pads, and filled up the brake fluid.. I tried bleeding the brakes by unscrewing brake line and pumping brakes..
I thought that was right, well when I got in car to drive an test... The brakes push all the way to the ground! To stop you have to pump them like 10 times!
Help, I've searched and couldn't find anything.
Thanks!
Milly is offline   Reply With Quote
Old 05-26-2012, 04:35 PM   #2
starfire240's Avatar
You probably bled the system wrong. You need to start over again.
Make sure the reservoir is full. Ask someone to pump the brakes for you. Start with the passenger side rear wheel and ask your helper to hold the pedal down and open the bleeder. close it and then repeat the process again till you don't see air bubbles coming out anymore. Repeat this with every wheel in the order of pass rear, driver rear, pass front, driver front. Make sure the reservoir stays full throughout the process.. Pm if you got any questions
I wish 240s came FWD and with VTEC...
starfire240 is offline   Reply With Quote
Old 05-26-2012, 05:33 PM   #3
Thanks! You have a pm!
Old 05-26-2012, 05:37 PM   #4
cotbu's Avatar
I'm sure you meant the bleeder screw. If you're doing this by yourself you need to keep the pedal to the floor, before you bleed out and close the bleeder. Tip add a hose to the bleeder, put it in a bottle with fluid. U do this so you don't suck in air before the bleeder is closed. Use a Jack handle on the seat to keep the pedal to the floor. Or get another human being.
Sent from My Highly Tuned Vibrant, Running Jellybean!!!
cotbu is online now   Reply With Quote
Old 05-26-2012, 05:40 PM   #5
Ahhh I never turned the bleeder screw... I literally just un bolted the brake line.... That makes since!!!!
Is that order posted above correct?
Old 05-26-2012, 05:57 PM   #6
cotbu's Avatar
Technically no! LR, RR, LF, RF then if ABS equipped, bleeder on abs
Old 05-26-2012, 06:42 PM   #7
KiLLeR2001's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
This is wrong. I know this is what it says in the 240SX FSM but it is a misprint since its the same order as the RHD 180sx/Silvia vehicles.
180SX = LR, RR, LF, RF
240SX = RR, LR, RF, LF.
Although essentially you can do it in any order and still bleed properly if you are thorough enough. It's just that the proper order is most likely the quickest.
KiLLeR2001 is online now   Reply With Quote
Old 05-26-2012, 06:44 PM   #8
Great ill do this tomorrow I was sooo frustrated!
Thanks a ton!
Old 05-26-2012, 06:45 PM   #9
Ah thanks or the clear up.. Will do this order then.
Old 05-26-2012, 06:59 PM   #10
cotbu's Avatar
That's why I said technically. NISSAN FSM wrong again!
The split between LR & RR seem to more on the right side, so I always do LR for first.
Old 05-26-2012, 11:31 PM   #11
Yea you're right but like you said.. If done properly it really doesn't matter which side
SEO by vBSEO 3.6.0 PL2
