Old 05-16-2012, 11:46 PM   #1
davidpham's Avatar
new sr20det redtop won't turn over
Hi i just bought a redtop sr20det from a running car and was wonderign why its not turning over. i turned the key the car looks like its about to turn on but it won't start. i tried putting in fuels but that doesn't help at it.
2001 Honda S2000 - current
WTB: S13 Silvia Hood
davidpham is offline   Reply With Quote
Old 05-17-2012, 01:13 PM   #2
davidpham's Avatar
heres a video of it
sr20det won't start - YouTube
Old 05-17-2012, 01:17 PM   #3
gretz's Avatar
ecu plugged in nice and tight?
gretz is offline   Reply With Quote
Old 05-17-2012, 01:44 PM   #4
davidpham's Avatar
yup it should be
Old 05-17-2012, 01:56 PM   #5
JDMRIDDAZ's Avatar
check for codes
check for spark and fuel...
make sure fuel lines r correct
check all grounds
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 05-17-2012, 02:02 PM   #6
davidpham's Avatar
Originally Posted by JDMRIDDAZ View Post
check for codes
check all grounds
1. havent check yet
2. check
3. check
4. check
Old 05-17-2012, 06:09 PM   #7
davidpham's Avatar
ecu red led stays on what does this mean?
Old 05-19-2012, 12:18 AM   #8
davidpham's Avatar
can anyone help?
Old 05-20-2012, 01:51 PM   #9
davidpham's Avatar
got it running thanks to 91drftr
Old 05-20-2012, 02:46 PM   #10
For posterity, what was the problem?
ST3ALTHPSYCH0 is offline   Reply With Quote
Old 05-20-2012, 06:16 PM   #11
davidpham's Avatar
Reason why it would not turn on:
1. bad grounding
2. big leak through the bov (greddy type rs bov) the big hole cause the car not to turn on until i put my hand over it.
3.battery was weak
After it turns on, the car seems to act weird like the engine was shaking bad and it bog when i stepped on gas. so I took out the z32 maf that was on the engine and switched it back to stock maf and now the motor drives perfect.
the only problem im dealing with left is why my jdm cluster's rpm and km/h not working. everything else seems to work except for those 2. anyone wanna help?
Old 05-20-2012, 06:32 PM   #12
Speed sensor?
Sent from my iPad using Tapatalk
projectblak is offline   Reply With Quote
Old 05-20-2012, 06:51 PM   #13
davidpham's Avatar
i checked the plugs under the transmission. 1 plug is plugged and the other plug that is deep deep on top is not plugged in
SEO by vBSEO 3.6.0 PL2
