Old 02-22-2012, 11:36 AM   #1
ill tongue punch her fart box
andrew600's Avatar
weak ebrake, no lock.
ive done new pads, and rotors within this last year, and properlly adjusted the ebrake cable nut. still is super weak and i cant figure out why. is there another way to adjust?\
91 s13 hatch.
full sr20det black top s13 swap for sale http://zilvia.net/f/sale-items/45494...-s13-swap.html
y u no buy.
andrew600 is offline   Reply With Quote
Old 02-22-2012, 01:32 PM   #2
andrew600's Avatar
forgot to add, the brake pedal doesnt feel sloppy or mushy, no brakes locking up so no air in the system either. i just dont get it.
y u no buy.
Old 02-22-2012, 01:40 PM   #3
cbcm2435's Avatar
what pads do you have in the rear? some pads dont have a great bite, i know my hawk pads suck with the stock e brake
cbcm2435 is offline   Reply With Quote
Old 02-22-2012, 01:41 PM   #4
I <3 My RPS13
Edwin562's Avatar
could be the ebrake cable be streched out??
Old 02-22-2012, 01:48 PM   #5
cotbu's Avatar
Assuming you've bled correctly and the calipers are working correctly and the pads don't suck. Step on the brakes a few time then pull on the ebrake lever while brake pedal is down. adjust the ebrake nut. Then roll the car or try to spin the wheels, if on jack stands.
They should be locked now!
Old 02-22-2012, 01:54 PM   #6
This is a common problem. I know mine are stretched the fuck out and won't lock up.
Originally Posted by Hensley
Not calm in any way, but it has a decent decoration. 4 degrees Angle of 17 x9 + 17 ~ 10 mm, 25 mm gaskets 215/45 / and serious, you need to release a way more standard, otherwise, this is all useless, just another picture thread.
Old 02-22-2012, 02:49 PM   #7
andrew600's Avatar
i actually do have hawk pads in the rear....
and i will also look into the stretched cable. is there an entire replacement i can just buy???
and ill try to do the jack stand locking thing.
y u no buy.
Old 02-22-2012, 02:49 PM   #8
LockOn!'s Avatar
THIS^
I've heard of this working a few times before. I think lot of people forget to properly set their brakes before adjusting the handbrake.
However, sometimes this fails too.
I've had this problem before and resorted to changing everything including the cables but that still didn't help. Its expensive and kinda a pain in the ass too.
Save yourself some time and just get these > Project Mu Brake Pads - D1 Spec - a-spec tuning - engine performance & suspension tuning
Epic lock-up. With them I probably didn't need to change my cables and rotors.
Only downside is they create A SHIT LOAD of brake dust. gotta wipe the wheels down frequently to keep them from turning grey lol.
LockOn! is offline   Reply With Quote
Old 02-22-2012, 03:19 PM   #9
andrew600's Avatar
hahhaha i have white wheels
but ill give the lockey thing a try and if no go, ill do cable and pads.
y u no buy.
Old 02-22-2012, 04:27 PM   #10
LockOn!'s Avatar
Also, just change the center cable first. That's usually the baddy.
Old 03-14-2012, 03:13 PM   #11
andrew600's Avatar
ok so i have done a little looking and testing, and my passenger side actually is locking but there is to much force built up without the other wheel locking to stop or slow down the car enough.
so i jacked up the car and found that on the little block where the cables split. when the brake is pulled they arent even with each other. the driver side the one thats not locking doesnt move at all really like its possibly stuck and the passenger moves as normal. should i replace the cable from here or both or try to free up the stuck cable if it is stuck and not streched.
y u no buy.
Old 03-14-2012, 03:38 PM   #12
evilpanamajack's Avatar
If your serious about your Ebrake, than just do the Hydraulic Hand brake mod
With one of these
http://www.ebay.com/itm/SICKSPEED-RE...74189d&vxp=mtr
u might find a better deal for one on zilvia
You just have to cut into your rear brake line, *not the ebrake cable lines
SHTFUCK
evilpanamajack is offline   Reply With Quote
Old 03-14-2012, 05:13 PM   #13
andrew600's Avatar
already have a hydro for the other car. not doing that with this one. this is strictly a daily car.
y u no buy.
Old 03-14-2012, 05:26 PM   #14
LockOn!'s Avatar
Change the one that's too long perhaps?
I wonder if the ebrake mechanism could be busted on that one side as well but I doubt it.
Idk, when I did this last year I remember seeing the same thing and tried to do everything one part at a time but it turned into a goose chase and eventually everything was replaced haha.
Old 03-17-2012, 11:50 PM   #15
dawnattack's Avatar
try to tighten the nut just below ebrake handle..
dawnattack is offline   Reply With Quote
Old 03-18-2012, 05:41 AM   #16
I have had exactly the same problem.
Don't bother with 33 handbrakes, hydro etc
Instal Project Mu d1 Spec brake pads
and
Uras hand brake assistors (you can copies of them here gktech.com.au for $30, unsure what postage to USA will be- not much i imagine.)
It went from not locking at all on lock, to locking in a straight line everytime, with minimal effort.
ziptie is offline   Reply With Quote
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
