| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Junkie ![]() | so where is the how to for changing the oil pan gasket? ![]() mines is leaking pretty bad.
__________________ (taeyeon gif here) |
| Sponsored Links | |
| | #3 |
| Zilvia Junkie ![]() Join Date: Oct 2009 Location: Florida Age: 25
Trader Rating: (20) Feedback Score: 20 reviews | It's simple drain the pan. Unbolt it. Remove the old remains of liquid gasket. Reapply and bolt it back up. Make sure you remove the RTV off of the upper pan also |
| | #4 |
| Zilvia Junkie ![]() Join Date: Jun 2010 Location: NORTH EAST LOS ANGELES Age: 23
Trader Rating: (14) Feedback Score: 14 reviews | also raise the engine a little so you wont have to struggle takin' it off.. loosen up the motor mounts if you dont have a cherry picker available get a good jack and jack it up where the engine meets the transmissin! |
| | #5 | |
| Quote:
bingo | ||
| | #6 | |
| Zilvia Junkie ![]() | Quote:
using the car jack ok?
__________________ (taeyeon gif here) | |
| | #8 |
| Leaky Injector ![]() Join Date: Jan 2011 Location: Philadelphia Age: 20
Trader Rating: (0) Feedback Score: 0 reviews | I would say just save up for a cherry picker, keep adding/checking oil until you can afford to safely change it. Buying a $35 bug thing of oil and adding a little every so often is much cheaper than anywhere from hospital bills because of an accident to a funeral. Those bitch jacks for changing tires not maintenance. |
| | #10 |
| Zilvia Junkie ![]() | ^^don't use pre-cut cork gasket what about different material gasket? RTV, just make a gasket with it? BTW,how many bolts for the motor mount do i have to loosen?
| | #15 |
| Zilvia Junkie ![]() | just use a jack. heavy duty jack.... your going to be working with your hand in between engine and crossmember.. heres the steps. 1.raise car on jack stands. 2.loosen engine mount bolts till almost very last thread 3.jack up engine from where the tranny meets engine and make sure to put a 2x4 so it wont damage anything. also make sure youll still be able to get to the bolts on the back. 4.unbolt the sway bar and careful with it swinging down towards your forehead lol 5.unbolt the pan in order. check fsm. taking off the pan is tricky you have to kinda manuever it around. 6. clean and put rtv on oil pan 7. repeat backwards and tighten everything.
__________________ "My car got into a fight with a 18 wheeler, and the truck won." |
| Sponsored Links | |
| | #16 |
| Zilvia Junkie ![]() Join Date: Feb 2011 Location: greenwood s.c. Age: 28
Trader Rating: (10) Feedback Score: 10 reviews | youve already got a lot of responses but I think this is what youre looking for www.ka-t.org :: View topic - How to: S13 Oil pan removal
__________________ |
| | #17 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
