Old 04-14-2011, 06:07 PM   #1
new alternator,electrical problems?
so i recently did a ka24de swap, had to put a new alternator on because the other one was junk, now none of my electrical stuff works, like the seatbelt sliders, the tach and temp gauge, dash lights, tail lights, my headlights work and my fan works,they are on separate switches. i dont think the o2sensor is reading either and that is new. the horn doesn't work too. but i can start it run it for like 15 seconds till it dies. i read in a different post the alternator could have something to do with this. maybe its just nasty grounds?
feyd_w is offline   Reply With Quote
Old 04-14-2011, 06:45 PM   #2
Make sure the power stud on the alt isn't grounding out on anything. When i did my SR, mine was touching my power steering lines and grounded out causing my whole harness to burn up. Also check all your fuses. If it did ground out for any reason it could have blown a few.
McSlides is offline   Reply With Quote
Old 04-14-2011, 09:10 PM   #3
nissan junky's Avatar
Did you check the alt fuse,that will cut out all these powers but not the (run it for like 15 seconds till it dies)i think its another problem...
nissan junky is offline   Reply With Quote
Old 04-18-2011, 05:55 PM   #4
alternator fuse was blown and the stud on the alternator was grounding, thanks
Old 04-18-2011, 08:23 PM   #5
Welcome to help...
Old 04-20-2011, 09:15 PM   #6
!!chuy!!'s Avatar
ive searched a bit and also been to three diffrent autoparts stores localy in my home town, does anyone know were i can get a 75v alt fuse....?
mine is blown
!!chuy!! is offline   Reply With Quote
Old 04-20-2011, 11:03 PM   #7
Mishkin_707's Avatar
local junk yard should have them, check all early 90's nissan vehicles, i think they are $free.99 if you play your cards right, i'll check tomorrow if i have one, if i do i can just send it to you
Mishkin_707 is offline   Reply With Quote
Old 04-21-2011, 12:08 PM   #8
mine is blown
yea your best bet is junkyards
SEO by vBSEO 3.6.0 PL2
