| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Addict ![]() Join Date: Feb 2007 Location: socal (909) (951) Rep Power: ♥♥♥♥♥ Age: 25
Trader Rating: (13) Feedback Score: 13 reviews | Hi guys. I have a question about my car stalling during turns, but only in the right direction. Everything is still on (just as if the car stalled in gear) lights, radio, everything is cool. Another peculiar event is while drifting the car through left handed corners the car performs awesome, as soon as you initiate into a right handed corner the car calls it quits as soon as the car starts to swing out. The power steering cuts out, & the engine stops running. Any Ideas? It's almost as like the car refuses to make brisk right turns or drift counter clock wise. My car is a 96 S14 with an un-modded original motor. Thanks fellas. |
| Sponsored Links | |
| | #2 |
Trader Rating: (0) Feedback Score: 0 reviews | Idk but maybe the fuel is not being baffled does this happen on full tanks as well or are you always running on low because I know well at least on s13's the fuel pick up is on the right side but s14's may be different so if you make a right turn all the fuel goes to the left and left turn all the fuel goes towards the pickup. |
| | #3 | |
| Zilvia Addict ![]() Join Date: Jan 2010 Location: SoCal/Ft Worth TX Age: 19
Trader Rating: (2) Feedback Score: 2 reviews | Quote:
__________________ | |
| | #4 |
| Zilvia Member ![]() | I agree on checking the harness on top of the drivers side wheel. . Also make sure that a engine ground isn't coming loose like at the back of the engine. I had a problem similar to this, and the wire was slowly breaking off the metal screw post because my engine mounts were bad. |
| | #6 |
Trader Rating: (13) Feedback Score: 13 reviews | Thanks for the replies everyone.. I'm pretty sure it's a faulty fuel pump now because the car gives up at random even driving straight. Will bump again after that is switched out. ![]() |
| | #7 | |
| Join Date: May 2011 Location: San Juan, Puerto Rico Age: 35
Trader Rating: (0) Feedback Score: 0 reviews | Quote:
This problem is really strange and I will like to know if you found a solution to your problem as it is similar to mine. I will really check the car tomorrow and look for striped or grounded wires or cracked vacuum lines, but if you guys can point the way will be appreciated. Thanks from Puerto Rico. | |
| | #10 |
Trader Rating: (0) Feedback Score: 0 reviews | Thanks for the reply!! On the first laps I did everything was perfect, my fuel level went below 1/4 tank after some laps, so there is a possibility that on the sloshing from side to side of fuel some dirt on that 16 year old tank was sucked and ended on the filter. Your reply makes a lot of sense. Will replace the filter ASAP and go from there!! Had not thought of that! ![]() |
| | #11 |
Trader Rating: (0) Feedback Score: 0 reviews | Before posting I did a search on this forum and others and only here I found a similar problem, did not want to ask something that was answered a million times before so you guys wont yell at me. On that search I found that somebody made the same recommendation as you but on a different stall problem, so that was already cheeked and found no rubbing problems. Thanks for your reply!! |
| | #12 |
Trader Rating: (0) Feedback Score: 0 reviews | This is the new Love of my life by the way. Wanted one since 95 when I first lay eyes on one. Finally and after kids and the whole getting married stuff and a Honda Odyssey and some other non-fun modes of transportation I got myself one. Sorry if I'm off topic just wanted to share. |
| | #15 |
Trader Rating: (0) Feedback Score: 0 reviews | OK guys I think I finally got it. After following all your directions the car still had the problem. The only thing left on that "to do" list was to replace the fuel pump, so I got a new one and proceed to install it. Being a new guy on 240's I downloaded the car service manual and with it at hand started the work. Once I removed the plastic lock washer and lifted the assembly where the pump, sender unit and hoses connect the big plastic "buoy" and the pump came right out. Up until now nothing strange until I started the reassembly. The manual showed some brackets that hold the pump and sender unit in position that I was able to locate with a flashlight, it took some time but I was able to get the sender unit and pump on their brackets. Before they were not (and come to think of it I was hearing some noises from back there that I was not able to pinpoint). Went out for a drive and some "spirited" driving on some on-ramps (you know the ones that go around to the right) and the problem is nowhere to be found, and my fuel gauge is super steady, before it danced around (which I attributed to the car being old), if fact I lost 1/4 tank of fuel!!! So the real test will be on the track, will let you guys know, Thanks a lot for the help, appreciated. Without it I will have never found the lose pump and sender unit. THANKS ![]() |
| Sponsored Links | |
| | #16 |
| Post Whore! ![]() Join Date: Jun 2005 Location: GRRRVINE!!! Age: 30
Trader Rating: (12) Feedback Score: 12 reviews | i had this exact problem it was because the fuel pump wasnt mounted on its bracket and was swooshing around in there. Should be done deal if you mounted it back and its in there solid.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
