Old 01-03-2011, 04:57 PM   #1
Drift_86's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
trying to put r33 calipers on my s14
ok i just got this caliper and i need some info.
1.correct me if im wrong but this are r33 caliper right?
2.is it true i can use z32 convertion brake lines?
3.can i also use z32 pins, shim, and brake pads?
4.is it true i can fit q45 or z32, r32 rotors?
5.how do you know you need to rebuild your calipers? if so can i use z32 rebuild kits for this calipers?
6.i could use z32 bmc rihgt?
Old 01-03-2011, 09:20 PM   #2
R33 and z32 calipers are the same. its still a sumitomo caliper so yes z32 parts work. i would rebuild them if there off the car since there easily 15ish yrs old and its not that expensive.
Nkelley is offline   Reply With Quote
Old 01-03-2011, 10:15 PM   #3
Drift_86's Avatar
Trader Rating: (42)
Great thanks! but I know the rotor r different aren't they? I can't find rotors for this and everywhere I search they only have z32 and r32 they don't even mention r33. I know read somewhere that they had a different size?
Old 01-03-2011, 10:30 PM   #4
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (177)
Feedback Score: 177 reviews
Send a message via AIM to drift freaq
Actually that is not exactly correct. R33 uses a larger diameter rotor. So you have to cross reference the rotor size as a Z32 rotor is to small. I believe MrMcGarrett cross referenced a rotor that works.
1991 Azzurro California Metallic S13.5 VQ35 project in the works!
1993.5 Primera Daily driver.
Originally Posted by bc. View Post
I know everyone hates when they get bad head, but I paid allot for this and I guess I was expecting better from a pro.
Buy my mounts!
Old 01-04-2011, 12:18 AM   #5
thanks for the correction. i was under the impression they were the same. good info
Old 01-04-2011, 01:25 AM   #6
Drift_86's Avatar
Trader Rating: (42)
So do q45 rotors fit? Everthing else I can use z32 parts?
Old 01-05-2011, 04:31 AM   #7
I </3 VA
fliprayzin240sx's Avatar
They do and they dont. Q45 rotors are the same diameter as R33s but the thickness isnt the same. IIRC they are 28mm vs 30mm and both are 296mm diameter wise. They use the same pads and hardware as Z32/R32. R33 brakes are better because of the larger rotor.
CLICK HERE!!!
FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate
fliprayzin240sx is online now   Reply With Quote
Old 01-05-2011, 12:44 PM   #8
i was about to start this thread myself, for my s13 though.
only difference i'd need to know is the rear, i have both Z32/R33 calipers pads and rotors,
for my daily, i was assuming the Z32 setup F+R and the track car the R33 breaks, but what if i wanted to upgrade my rotor? my R33 rotors need new rotors or a machining, so i wanted to go a larger rotor anyways.
the pbm rear rotor is for oem rear caliper, and i cant find rear r33 big break rotor anywhere, is my only solution to get the oem rotor i have machined?
annnd third question would be, is a big break rotor upgrade worth it? i wanted it in the rear for my hydro ebrake setup. im looking for the best lock i can get, if the oem R33 caliper+rotor is good enough than so be it i suppose.
uperformance is offline   Reply With Quote
Old 01-05-2011, 06:21 PM   #9
Drift_86's Avatar
Trader Rating: (42)
yeah so 2mm wouldnt make a diffrent would it? they would still work with no problem?
Old 01-06-2011, 05:39 AM   #10
Dude,
96+ Q45 is 296x30 mm rotor same as "R33" crap. get them for like 40$ each @ autozone.
96+ NOT 91-94 Q45.
lines rebuild kit other crap same as Z32 stuff.
My 320mm EVO rotor are > > > > > your R33 stuff
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 01-10-2011, 01:53 AM   #11
Trader Rating: (44)
Feedback Score: 44 reviews
yup well all these guys pretty much helped u out the bmc will work the q rotors will work but id go with the 30mm z32 for better performance and as for the lines yes the z32 ones work pretty much the gtr calipers are same as the z32
murffy is offline   Reply With Quote
Old 01-11-2011, 04:53 AM   #12
Just finished this swap on my s14. Ran into some issues with the rear with having to swap the e brake set up... more just a pain in the a** to do but not too bad. i ran just the front swap for a while on the stock BMC but once you put the rear on switch to the Z32 BMC just make sure it has the 3rd fitting!!! the first BMC i got didnt have it check ebay there like 100$. also i think there are 2 different size Z32 calipers because 240sxmotoring sells 2 different size rotors, I lucked out when i got my rotors so dont quote me. when i put the front calipers on i had to make some shims to line up the space between the caliper and rotor.but other than that the front swap is really easy. as for the e brake cables the Z32 n/a cables work you dont have to look for R33s. NAPA, Advanced...
check out 240sxmotoring.com they have helped me rebuild my car great site!!
S14Driftn4life is offline   Reply With Quote
Old 01-11-2011, 01:17 PM   #13
HYPNOTIK's Avatar
Send a message via Yahoo to HYPNOTIK Send a message via Skype™ to HYPNOTIK
What he said. The closest rotors you're gonna find are 2000 Infiniti Q45.
HYPNOTIK is offline   Reply With Quote
Old 01-11-2011, 01:21 PM   #14
HYPNOTIK's Avatar
Originally Posted by Ali 556 View Post
Dude,
96+ Q45 is 296x28 mm rotor same as "R33" crap. get them for like 40$ each @ autozone.
Fixed. Like Ray said, there is 2mm difference.
As far as pads, hardware, and rebuild kits go everything is exactly the same between turbo R33 and Z32. The rear brakes are exactly the same between turbo R33 and Z32. The only difference is the front rotor size, 296x30mm for R33 and 280x30mm for Z32. They both bolt up exactly the same. I've had R33 brakes on my last three Silvias, they are direct bolt on. You don't need any shims or any crazy shit. The R33 ebrake cables also bolt right up to S14 and S15, ask me how I know. And, regular turbo R32 brakes are the exact same as Z32, everything. R32 GTR are the same as R33 except with a 2mm thicker rotor. R32 GTR front rotors are 296x32mm.
Here's some pictures.
Z32/R32
R33/R32 GTR
One more, notice how I had to cut the dust shield out of the way to clear the bigger rotors.
Z32/R32
R33/R32 GTR
Old 01-11-2011, 01:37 PM   #15
Firestorm's Avatar
Send a message via ICQ to Firestorm
so much misinformation in this thread...
R32 GTR non-vspec and R33 GTs-T share the same calipers (the ones you have), rotors and pads except for the fact maybe that there were drilled rotors available for the R32 GTR from factory. the rotors for these calipers are 296x32mm. Z32 TT calipers use 280x30mm rotors, Z32 NA 280x26mm...
R32 GTs-T uses Z32 TT calipers, 280x30mm.
i doubt that Z32 pads will fit in the R33 caliper but if they do, they won't use the rotor surface as effectively as the R33 pads would.
and before anyone asks, i've worked with all of those brake setups but never mixed and matched. but about the rotor sizes im 100% certain.
Firestorm is offline   Reply With Quote
Old 01-11-2011, 01:50 PM   #16
creyes13491's Avatar
heres the caliper info that i saved a while back.
nissan caliper info
R32 T : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T (early) : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T type m : 280mm x 30mm (4 pot sumitomo caliper)
R32 GTR : 296mm x 32mm (4 pot sumitomo caliper)
R32 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R33 GTS-25 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-4 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-25T : 296mm x 30mm (4 pot sumitomo caliper)
R33 GTR : 324mm x 32mm (4 pot brembo caliper)
R33 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R34 GT : 296mm x 30mm (4 pot sumitomo caliper)
R34 GTT : 310mm x 30mm (4 pot sumitomo caliper)
R34 GTR : 324mm x 32mm (4 pot brembo caliper)
Z33 NA : 324mm x 32mm (4 pot brembo caliper)
Z32 NA : 280mm x 26mm (4 pot sumitomo caliper)
Z32 TT : 280mm x 30mm (4 pot ali sumitomo caliper)
S14, S15 : 280mm x 30mm (4 pot sumitomo caliper)
creyes13491 is offline   Reply With Quote
Old 01-11-2011, 06:15 PM   #17
Drift_86's Avatar
Trader Rating: (42)
nissan caliper info
Whoa now I'm really confuse, what size r33 calipers do I have?
Old 01-11-2011, 06:29 PM   #18
DJDANGER24's Avatar
have you tried measuring the bridge gap in the caliper to see if its in fact a 30mm caliper ? By that i mean the gap where the rotor passes in between the caliper, just outside of the pads. or have you only relied on what you have read and not even applied any of this info ?
DJDANGER24 is online now   Reply With Quote
Old 01-11-2011, 06:42 PM   #19
Drift_86's Avatar
Trader Rating: (42)
kinda i was just gonna go to phase2 and have them measured them and end up paying more for them... if i can find the correct spect i would buy them off ebay or something
Old 01-11-2011, 08:55 PM   #20
DJDANGER24's Avatar
i dont get what your trying to say. why cant you measure it yourself ?
in this picture, measure the gap in the middle/bottom of the right caliper. it should be about 32mm wide, enough to fit a 30mm wide rotor. If its smaller than that, then you have a 26mm caliper
Old 01-11-2011, 09:37 PM   #21
Drift_86's Avatar
Trader Rating: (42)
Okay thanks! You been really helpful
Old 01-12-2011, 12:45 PM   #22
HYPNOTIK's Avatar
Most likely you have GTS25T calipers. The others aren't 4 pots except the GTR and they are Brembos.
Old 01-15-2012, 07:26 PM   #23
Wow just wow its 2012 just wow
stockdrift is offline   Reply With Quote
Old 01-15-2012, 07:29 PM   #24
SR/RB Guru
Sileighty_85's Avatar
Yeah and it was 2011 until you bumped this year old thread for no reason
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-01-2012, 11:01 PM   #25
Happy new year thread!!!!!!!! May all ur wisdom be helpfull.......lol
Mjc24 is offline   Reply With Quote
Old 04-30-2012, 02:27 PM   #26
Firstly Apologies for bumping up this thread. I am using a R33 4 pot sumitomo calipers. 296X idk what mm. Now im looking to get a bigger rotor for my front. Really confused what rotor could be used with this exact same calipers on the First Post.
Appreciate any replies. Thanks. For brake pads, i found hawk do sell R33 GTS-25T pads from driftworks. Really hard to find other brand pads thou. Any suggestions? =)
nash-singapore is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/s-chassis/360600-trying-put-r33-calipers-my-s14.html
Posted By For Type Date Hits
R33 brakes This thread Refback 12-16-2012 07:09 AM 6
specV brembos - Page 2 This thread Pingback 08-03-2012 07:42 PM 6
SEO by vBSEO 3.6.0 PL2
