Old 11-20-2009, 11:01 PM   #1
Exclamation Need help with my SR20 det red top Silvia
The car won't rev past 4500 rpm. Checked all the hoses and there are no air leaks, so I have no clue what the problem is.
Afghan Trooper is offline   Reply With Quote
Old 11-20-2009, 11:07 PM   #2
wangan_cruiser's Avatar
could be your maf
Old 11-20-2009, 11:08 PM   #3
puro pinche party ( )o( )™
Team DET's Avatar
Originally Posted by wangan_cruiser View Post
could be your maf
i second that
KG5 1990 240sx-SR20
2004 Titan-VK56 FTW
Team DET is offline   Reply With Quote
Old 11-20-2009, 11:42 PM   #4
clean your maf, and or try it out on a freinds car and see if his/hers does the same thing...
1995 240sx SE (current)
Ceepo is offline   Reply With Quote
Old 11-21-2009, 12:12 AM   #5
Joey89s13's Avatar
timing timing timing
Joey89s13 is offline   Reply With Quote
Old 11-21-2009, 12:17 AM   #6
I already cleaned the maf and it made it a little better but it still does not go past 45xx revs.
Old 11-21-2009, 03:22 AM   #7
try to switch with a different maf.
Old 11-21-2009, 03:29 AM   #8
I am going to take a wild guess here but check your 4th and 5th gear sensors. Make sure they arent shorting out on each other. I say this because 4th and 5th have gear based rev limiters and one is at 4500. Forgot which one, but either way check them.
LayNLow is online now   Reply With Quote
Old 11-21-2009, 07:11 AM   #9
army240's Avatar
Make sure you have enough fuel pressure
army240 is offline   Reply With Quote
Old 11-21-2009, 07:22 AM   #10
could be your maf
also try checking the MAFS wiring if you recently did the wiring. Then check to make sure the connector is connected securely.
For Sale:SR head w/internals,mafs,inj w/rail,frontcover w/pump,3" dp.PM ME!
VNG704 is offline   Reply With Quote
SEO by vBSEO 3.3.0
