| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Leaky Injector ![]() | god bless it and she ran soo good ok so last night i was driven the s14 home from a friends house on the i10 and i went up a bridge..well ya know how the base of the bridge is kind of a bump well i jumped up about an inch of the ground and ass soon as that happened my car lost all power...everything electronic was working but my car jus slowed down as i hit the gas peddle as if the motor wasnt even on but was in gear....i got to the side and tried to start my car and it wouldnt start it jus turned over and did nothing and i tried again a minute later and it sounded like it was on 2 if not 1 cylinder...i doubt i blew my head gasket and i wasnt actin like an ass wit the car and im stumped im obviously gettin gas bc as i tried to start it was and i could smell gas comin out the exhaust and i could hear my fuel pump i checked all my fuses and my wire harness in my fender well and nothing is wrong so i hav 2 choices(spark or compression) im scared shitless that i hav no compression i need help asap so someone please shed some light |
| Sponsored Links | |
| | #2 |
| im sure you have compression and all that. I would check your grounds and stuff. make sure your wires are all on and such. also if you have a stereo system and a fuse in line with the amp cable... they come loose once in a while and cause instability in the electronics | |
| | #4 |
| Zilvia Addict ![]() | Sr's don't have distributors... It's either a loose connection somewhere or your ignitor/CAS took a shit, but I think the CAS is highly unlikely to go dead from a bump.
__________________ Built 95' S14.... |
| | #5 | |
| Violent Running Asshole ![]() | Quote:
Just thought I would fix that for you. | |
| | #6 |
| Zilvia FREAK! ![]() | I don't understand the title of this thread but oh well. I would definitely check all electronics, do you know if you bottomed out?
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
| | #7 | ||
| Leaky Injector ![]() | Quote:
i made my name a long time ago when i liked sr's Quote:
anyways im getting spark jus not alot so im thinkin dizzy i hav a new one but i keep puting the install off (im really lazy lol | ||
| | #8 |
| Doctor Chips ![]() | I had the ECS(whatever they call power to the ECU/fuel pump circuit) relay die on my S13 when I hit a pothole in downtown Atlanta. Kinda sucked because I was trying to push it up a slight incline by myself as all these homeless guys were milling around. Had similar symptoms, no power on the affected circuit, and all fuses were fine.
__________________ 06 Infiniti G35 Coupe 6 MT - Diamond Graphite/Stone 92 Nissan 240SX S13 Hatch GT2876R - Constantly tinkering and lots of garage naps... Safety Red/Gloss Black |
| | #10 | |
| Quote:
If your car is running on two cylinders find out if you're getting spark on those cylinders. Do all electronics (lights, radio, brake lights, etc) work? | ||
| | #11 | |
verything is fine but im not gettin much spark which is why i say dizzy | |
| | #12 |
| Premium Member ![]() | check your cap and rotor, my ka when i had one ran like shit/ didnt want to run i cleaned those and it ran awesome, i would check grounds to nissans have a bad grounding problem...
__________________ 1995 240sx SE (current) |
| | #14 |
| Zilvia Addict ![]() | I assumed it was turbo. I know N/A's have a distributor, but who goes through the effort to put a weaker motor than the KA in?
| | #15 |
| Leaky Injector ![]() | |
| Sponsored Links | |
| | #16 |
| Leaky Injector ![]() | she lives...kinda i found out that toyota 4 runners hav the positive and negative on opposite sides as the 240 so i blew mos of my fuss but dammit tha bitch started up the first try i forgot that i took my exhaust off so i jumped like 10 feet in the air when i started her up |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
