Old 11-05-2009, 11:08 PM   #1
S13RB25DETDRIFTER's Avatar
Z32 Brake Swap S13 HELP
i got a 1inch master and everything bled but i loose the pressure in the pedal what can be the problem i bench bleed my master cylinder too i got steel lines and pads are new and rotors but the pedal is driving me insane i get the braking power at the end of the pedal
S13RB25DETDRIFTER is offline   Reply With Quote
Old 11-05-2009, 11:11 PM   #2
Pink GodziRa
Dousan_PG's Avatar
are your calipers upside down?
did u bleed your calipers in the wrong order?
Aaron
Pink GodziRa
Dousan_PG is online now   Reply With Quote
Old 11-05-2009, 11:12 PM   #3
how can they be upside down ? yeah i bled from Rear left to front Right
Old 11-05-2009, 11:13 PM   #4
Pink GodziRa
Dousan_PG's Avatar
z32 calipers can be upside down
bleeder screw needs to be at top not at bottom, or you'll always have air in them.
Aaron
Pink GodziRa
Old 11-05-2009, 11:15 PM   #5
thats probably it cus i think its on the bottom dang ima change them tomorrow
Old 11-05-2009, 11:21 PM   #6
Pink GodziRa
Dousan_PG's Avatar
yeah just flip them
i did the same thing years ago. its the most common error for z swaps. no biggie. you'll be fine after that.
Aaron
Pink GodziRa
Old 11-05-2009, 11:24 PM   #7
yeah because my pedal is all to the floor and im like why if i got a 1 inch master and bled why is it still doing that but thanks man for the info
SEO by vBSEO 3.3.0
