| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Zilvia Member ![]() | Gas door won't open I DID search, however found no helpful information.... So the other day I went to the gas station and used the lever to open the gas door and nothing. I had to open my trunk and reach through the trunk lining to open the gas door. What would cause the gas door to not open, and how do I go about fixing it?
__________________ "Man is only flesh, until he has created his dream" |
| Sponsored Links | |
| | #2 |
| Premium Member ![]() | Seen this on a few cars the plastic retainer could be old/brittle/busted or the rubber sheath on the line could have broken this is the case on my daily at the moment would need to replace the line and I've just been to lazy/don't care enough to do it.
__________________ S-Chassis/Z32 Rear Upright Spherical Bearing Group Buy |
| | #3 |
| SLINKY + ESCULATOR = Fun Times ![]() | Can you still open the trunk from via the lever? If you can, then the plastic piece holding the popper may have broke off. If you cant, then the cable is snapped, time to replace it.
__________________ |
| | #4 |
| Premium Member ![]() | I can open my trunk with the lever but not the gas latch and I've looked at the cable and it is broken guess it depends on where the break is
| | #5 |
| Zilvia Member ![]() | Yeah, I can still open the truck with the lever, but not the gas door. I'll look into it here soon. I plan on stripping the car down to get ready for body work
| | #6 |
| Post Whore! ![]() | Check the small tab that pops the door out. Have someone hold the release and use something flat to see if you can lift the door out. If that piece is broken the door will never pop out when you release the latch. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
