| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| If I let the car warm up from idle to fully warm, once the car is fully warm the idle will start to bounce some and my vacuum will jump around from 17-20. When I go out and drive the car is runs fine and boosts properly. If I stop at a light the idle will not bounce and the vacuum and steady at 20. Its only random when it happens Another problem is that my narrow band o2 sensor is reading more lean then normal when I am idling and leans out off the chart when I go into boost. I know I am ruining rich, I can smell it and black smoke comes out when I go into boost. I didn't know if this meant the o2 was shot. I just installed a electronic boost controller but the car ran fine and the o2 sensor read rich after I installed it. The problem came up about a week later. Tell me what you think, thanks! | |
| Sponsored Links | |
| | #2 |
| Post Whore! ![]() | i dont think it's your o2 sensor. try unplugging it. mine didn't make a difference whether i used it or not.
__________________ Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
| | #3 |
| Premium Member ![]() | Only way to know for sure weather an O2 sensor is busted is to check the signal Cosult or a quality graphing multimeter would be needed to do so signal should oscillate ~5/second over a 0-1 volt range IIRC Most SR swaps I've seen tend to run rich which probably is why SoguRacing you didn't notice a difference when you unplugged it OP: sound to me like you may have a vacuum leak somewhere or your MAF is loose/dirty
__________________ S-Chassis/Z32 Rear Upright Spherical Bearing Group Buy |
| | #4 |
| Post Whore! ![]() | your o2 sensor reading isn't used when under heavy load. you're in open loop. so the black smoke is a tuning problem or other related issue.
| | #5 |
| So I drove the car today for a while pushing it hard. The a/f gauge starting reading normal again. I know I'm running rich so I guess the o2 sensor got clogged up, I checked my spark plugs they aren't caked up or anything. Another weird problem is that when I set my adjustable FPR to 3 bar, by the time I'm done driving it will have dropped 5-7psi, any suggestions? | |
| | #6 | ||
| [JEFE S14] ![]() | Quote:
| | #7 |
| Zilvia Junkie ![]() | im having the exact same problem i from the looks of it the ecu temp sensor is possibly going bad. its like 20 bucks so im gonna do that first maybe you should check it out too i know my tune is fine cuz ive changed the ecu like 5 times and its the same crap. only happens after warm up! p.s. not thread jacking
__________________ Yea sure its a stock turbo... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
