| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| s14 coilovers on s13 w/ skyline alluminum knuckles? Hey guys I'm building a track silvia and I figured a way to cut down a bit of weight is using s14 coilovers (as the fronts fit already) and rears and fitting them up to skyline alluminum knuckles w/ the tapered steel ball ball joints. I am just wondering if this will work. I know I would need to use the lower control arms from the skyline but would this even work? I assume there would not be much difference between heights of the s13 to s14 by switching over rears or am I wrong? | |
| Sponsored Links | |
| | #2 | ||
| You got me runnin up the walls ![]() | Quote:
FAIL. just buy the right coils for your car. end thread
__________________ Quote:
| | #4 |
| Zilvia Junkie ![]() | what you need to do is search. its been covered already. Use z32 rear knuckes (alum) and correct tapered balljoint (IIRC Q-45 has what u need). then u need a lower mount. you can eithor get z-32 rear coils, with s-13 upper mounts. OR get/mondify lower mount on coil-over to fit knuckle. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
