Old 11-02-2009, 02:45 AM   #1
S14: Popping noise during slow turns
It starts to make this popping noise recently. This happens when I am driving really slow (almost rolling speed). It happens to both left and right side. I have done the following things to the front suspension:
New OE struts tops with KYB AGX and RSR springs
New Moog FLCA ball joints
I am planning to do the following:
Rebuild power steering rack
Tension rods
Thanks in advance
Jesse
BTW, does anybody knows if a fully loaded IS350 (I mean fully loaded like NAVI, heat/cold seats, like everything) has stock bigger wheels at the back? Looked at one today and:
Stretch tires running 225/40/18 front and back
Passenger front wheel has a dent
Any of the above would cause shaking? I am not talking about the steering wheel, but the ride is shaky. The steering seems fine.
chituntang is offline   Reply With Quote
Old 11-02-2009, 03:08 AM   #2
SoguRacing's Avatar
Send a message via AIM to SoguRacing
wheel balance
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-02-2009, 09:03 AM   #3
yes on the IS350. stock wheels are 18x8 front and 18x8.5 rear...unless its AWD
So its true, asian women are tighter than usdm women!
japslapsilvia is offline   Reply With Quote
Old 11-02-2009, 11:21 AM   #4
S13Sauce's Avatar
when u reinstalled the struts did you make sure the black cup on top was seated right on the springs? because i did mine on my old car and when i tirned the prings were poping around when i turned.
S13Sauce is offline   Reply With Quote
Old 11-02-2009, 11:41 AM   #5
Yeah. It's either that or something is loose. I had the same problem with my coilovers when one of the perches wasn't fully tight.
Dazzla is offline   Reply With Quote
Old 11-02-2009, 12:27 PM   #6
Ezel verkrachtende schijteter
!Zar!'s Avatar
Send a message via AIM to !Zar!
Noise during turning would most likely come from:
Loose nut on the top of the coilover.
Loose camber bolts on the top of the coilover.
Loose tension rod bracket.
Bad lower control arm bushing.
If it's under braking then it's most likely a loose brake caliper.
-=Mel=-
Old 11-02-2009, 12:42 PM   #7
c72c's Avatar
also the tie rods
or mounting bolts from the strut to the spindle
make sure all the shyte is tight that you installed, friend of mine had the same problem you're havin, the top bolt to the spindle was loose and the pop was the wheel camber-ing.
c72c is offline   Reply With Quote
Old 11-02-2009, 01:34 PM   #8
Thanks on the IS350 comment. That explains why the rear looks more stretch than the front.
As for my car, the strut tops were done at least a year ago. So I do not think it is the install.
Really need to study, but I guess I will do a little wrench before that...
I will check and see if all bolts are torque properly (brakes, tie rods, struts, and the control arms). And now come to think of it, it does make a funny sound when I brake...
SEO by vBSEO 3.3.0
