| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| ca18det no power.. hey ! i'm new on the forum ! it's really nice to see a bunch of people with lots of knowing to help ! i'm french so.. i'll do my best ! i'm a new owner of a silvia ca18det 1990 previously i had a toyota mr2 1992 lightly modded ( approx 270hp) and i sold it . now i'm in silvia! nice car, but what about the power? here is the mods on the car ''apparamently a t28 turbo ''( how to confirm this??) tein full coilover camber plate etc, tein conrol arm , ( car is really low and stiff i love ) DP+full exaust blitz nur spec air intake hks with adapter greddy s bov ecu blitz hks HG kazz 2 way diff stock boost, maybe 9 psi on cold temps ok now the probleme it's damn slow. ultra lag . car make no power until 4krpm, only psi before 4krpm, and after it goes to 7-9 psi, even a 7psi , it's seem slow like a have a leak. but i'm sure there is no leak. sometime car run great and power is nice , but is more ofter slow... maybe it's me, compare to my mr2, fast, quick spoot ( 16 psi @2500rpm), etc. but im sure , there is something wrong with my CA! today i put new spark plug, and planned to change de gaz filter.. it can't be bad !! so if someone could help me please !!!! mat.. tks! | |
| Sponsored Links | |
| | #4 |
| Zilvia Addict ![]() | when the car is running, unplug one at a time. you should notice a change in how the engine runs. If nothing changes when you unplug one, then the coilpack is dead and that cylinder isn't firing. On my CA, one of my coilpacks would just randomly cut-out, and then kick back in. Never did find out why.
__________________ Blow me, bitches. |
| | #6 |
| Leaky Injector | Sounds like a boost leak somewhere. Start by pulling codes off the ECU Could be timing, should be around 15* degrees stock. Have you even pulled the plugs to look at them?
__________________ Drift cars have no business being practical, fast, or functional. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
