| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Help! I just purchased an 89 coupe this week and i need some help... I hope you guys have some answers.. after looking over the engine bay.. I see a wire spliced into the EGI pump relay to the negative terminal of the battery. Any ideas of why the previous owner did this? i think this could be a reason why the motor is running rich. | |
| Sponsored Links | |
| | #2 | |
| Zilvia Junkie ![]() | Quote:
| | #3 |
| so would there be a ground problem or fuel pump problem.. when i disconnected the wire from the negative battery terminal the car wouldn't start it would turn but seems fuel isn't getting into the injectors. | |
| | #4 |
| Zilvia Junkie ![]() | nothing wrong with the pump, its a ground problem. Take a picture if you can, i would like to see the condition and locations of the wires involved. There is a major ground the runs through the fuse box, the - terminal from your pump relay should be spliced into that. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
