| S Chassis Technical discussion related to the S Chassis such as the S12, S13, S14, and S15. |
| | #1 |
| Leaky Injector | E-Brake Adjustment Tension OK, so I'm pretty much tired of how weak my e-brake is. Once upon a time I bought this car for $2000 and it was nice. Then I discovered that one of the e-brake lines was not hooked up to the caliper. The lock plate was just gone. OK, that's fine. I zip-tie it in, but it's just too weak and I want to adjust it to FSM condition. I don't even get tension till 4-6 clicks. How can I know when there is just enough tension on my e-brake? How can I know that I'm not destroying the cables/calipers? Are there any tips anyone can give me? Thanks, RentonD |
| Sponsored Links | |
| | #2 |
| Ezel verkrachtende schijteter ![]() | Under the ebrake handle is a nut. It's a 10mm. Hold the ebrake button and tighten that nut. It add tension as well as lower the handle so it doesn't look like you're stopping a train. Too much tension will cause your ebrake to be on even if it isn't up. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
